Built 4L60E transmission questions
Old Jun 23, 2003 | 08:40 PM
Flyer's Avatar
Default Re: Built 4L60E transmission questions
So will a 4L80E fit in a non hd turck, like my 03? If so has anyone done this yet?
Not without having to MAKE it fit. Not sure on alll the specific's but I think I'm on the right track.
Old Jun 23, 2003 | 08:58 PM
The 4L80E will fit,but the PCM for a 4L60E equipped truck will not work,so you have to use a stand alone computer to control the transmission's shift functions you also have to fabricate a driveshaft and do an outright purchase of the 4L80E transmission,flywheel and converter.
Old Jun 23, 2003 | 09:05 PM
StupidFast's Avatar
My Procharger seems to be a little harder on transmissions than people think. I make all of my torque at 3200. The only thing that I have had trouble with is the 3-4 clutchs.
A simple way to help the clutchs is line pressure. I take the pressure control soleniod out and give the torx a half of a turn. Re-stake it so it doesn't move back. It will not make the PCM do anything stupid because, it still thinks it is at stock pressure. Hope this helps.
Old Jun 24, 2003 | 12:19 AM
MarineBlue:
these are the links
transmissioncenter.net/4l60e.htm
levelten.com
both of these places are about the same cost for the transmission, and both are pretty much identical builds. As an option you can buy the valvebody kit, and tranny kit from each place to create your own for about $550 shipped. If you then have a reputable shop to do the work, it should not cost more then $400 to $500 to drop the tranny, rebuild it, and then reinstall it with a different torque converter.
I have a shop that will do it for $450 here in Vegas, so the whole thing will cost me about $1100, not including the cost of a new torque converter.
ferrellrooster
Mar 6, 2025 03:22 PM
zblee
63
Jun 10, 2023 01:25 PM
XL7
May 5, 2022 01:48 PM
USMCvet0311
Aug 1, 2015 07:45 AM
