Built 355 not what I expected
Old Feb 5, 2016 | 11:48 AM
  #21
94silverado's Avatar
Registered User
Vacuum & hard start like starter dragging or timing advanced a little too much
Old Feb 5, 2016 | 12:01 PM
  #22
Merctech2's Avatar
Get that new timing light and get that timing corrected before going any further. Its definitely got too much timing if it's hard to start when hot.
Old Feb 5, 2016 | 12:59 PM
  #23
TXsilverado's Avatar
So you dont know your afr, you dont know your timing, but youre asking for our suggestions????
Old Feb 5, 2016 | 02:22 PM
  #24
Registered User
Well yeah & you've got me going in the right direction,I appreciate it I really do,been out of turning wrenches for quite some time & got back into it but I'm older & the memory isn't like it used to be
Old Feb 5, 2016 | 02:34 PM
  #25
Merctech2's Avatar
This is what we are here for, helping each other. Any more? Just ask.
Old Feb 5, 2016 | 02:43 PM
  #26
Registered User
Thank you
Old Feb 5, 2016 | 02:52 PM
  #27
vmaxpro's Avatar
That setup should easily hit 325 flywheel hp
Old Feb 5, 2016 | 02:58 PM
  #28
Registered User
Yeah I was thinking 300'ish give or take,sometimes it's small things a person can look over several times & someone else can easy see or know how to correct it
Old Feb 5, 2016 | 04:20 PM
  #29
superbee's Avatar
should be good for around 400 horse man... like said get timing and WOT a/f dialed in before going any further
Old Feb 5, 2016 | 08:02 PM
  #30
Registered User
Obviously the timing was too high,got my timing light on it & backed it back down,the dizzy has 22 degrees built in so I set it about 14 degrees idling,that's all I had time to do this evening,it started just fine after I cut it off,did that several times,had to run kids places this afternoon,didn't get a chance to fool with it anymore but I'll get with it in the morning,thanks for all the help
Will get back in the morning
