Built 355 not what I expected
Old Feb 4, 2016 | 08:06 PM
94silverado's Avatar
Registered User
Default Built 355 not what I expected
Someone please try & help me,here's what I have,30 over 350,10:1 flat tops,292 comp cam ( 501 lift ) Edelbrock Rpm intake,msd ignition,hedman headers,demon 625 carb,40 series flowmasters,Edelbrock heads 64cc 185 runners,the problem that I think I have is maybe I overestimated what kinda horsepower I would have,I'm still running 4l60e with 2500 stall & 342's in the rear,the damn thing just doesn't seem to have enough umph !! Any ideas ?? Thanks !!!!
Old Feb 4, 2016 | 08:44 PM
FFDP's Avatar
You running a wideband at all to see if you are doing good on fueling?
It might be rich or lean and robbing horsepower.
Old Feb 4, 2016 | 09:00 PM
Registered User
It does seem a little rich,I wasn't running a thermostat so I put one in yesterday so it would be fully up to temp,started both mixture screws @ 1 1/2 turns out then slowly turned them until it changed the tune them backed off till it smoothed out,wasn't as bad as far as running rich but I think it should be stouter than what it is,kinda let down as I have a lot of money & time in it
Old Feb 4, 2016 | 09:13 PM
EmmerichLSx's Avatar
formerly Emmerich 5.3 (2013-11-30)
How much does the truck weigh?
Old Feb 4, 2016 | 09:16 PM
Registered User
Have no idea !! I'm sure she's heavy,swb reg cab 2wd
Old Feb 4, 2016 | 09:21 PM
Registered User
Gonna go out & say 4000 give or take 250 lbs
Old Feb 4, 2016 | 09:40 PM
The cam is rated to have power between 2500 and 6500. Does it feel like it goes pretty good in that area?
Old Feb 4, 2016 | 09:55 PM
Registered User
Not really,bout like an average stock 350,I've had stronger stock 350's that run stronger
Old Feb 4, 2016 | 10:03 PM
Sometimes those flat tappet cams will flatten out if the lifter bores are sticky or if the cam wasn't lubed well enough on first start up. Does it feel like it runs smooth when you floor it or is it kinda sputtery?
Old Feb 4, 2016 | 10:18 PM
Registered User
No sputters,I put plenty of moly lube on the cam,runs smooth no misses just don't throw my head back lol
Maybe the gearing is the problem ?
