Broke Crank Bolt
Old Oct 21, 2010 | 09:57 AM
aaronmc's Avatar
Default Broke Crank Bolt
So pretty much the worst thing that could happen did. When I was starting my cam swap yesterday while I was removing the crank bolt it snapped in half. So what are my options? Can it be drilled out? Do I have to pull the crank and have a machine shop try and remove it? Or is it pretty much screwed and I need a new crank?
Old Oct 21, 2010 | 10:32 AM
casper02's Avatar
Theres a special drill bit that spins the other way while ur drilling in so u can try that it vert effective
Old Oct 21, 2010 | 11:00 AM
I dunno, its loc-tited in there. Good luck though.
Old Oct 21, 2010 | 11:02 AM
aaronmc's Avatar
I should mention Ive swapped the cam before so this isn't the stock bolt its an ARP crank bolt.
blsnelling's Avatar
? Not from the factory.
Old Oct 21, 2010 | 11:03 AM
blsnelling's Avatar
How in the world does a hardened bolt of that size twist off? Did you install it with red Loctite?
Old Oct 21, 2010 | 11:05 AM
aaronmc's Avatar
Beats me. It started to come out then it got really tight and then snapped. No loctite at all.
Old Oct 21, 2010 | 11:19 AM
JFOLM's Avatar
Sounds like it was cross-threaded.
Old Oct 21, 2010 | 11:34 AM
53RUSSELL's Avatar
I had the same thing happen with arp bolt. I had to replace the crank because it was to hard to drill out in the truck. To replace crank in the truck isn't to bad it just sucks.
Old Oct 21, 2010 | 11:38 AM
aaronmc's Avatar
Im pulling the engine so maybe ill have better luck drilling it. I hope anyways.
