brake torque
Old Aug 22, 2005 | 02:46 PM
JERRY2500's Avatar
14 Second Truck Club
No problem Smoking them here
Old Aug 23, 2005 | 02:05 PM
Default pROBLEMS?
Originally Posted by JRsilverado
When you have 100% of the TM removed, does that take care of the abuse mode or is that something different? I had Allen remove all TM and It's still hard to spin the tires. I have 2 washers in my shift kit and I can't scratch 2nd. I have 3.42s and 285/60/18 GTIIs.
Hey, have you had any trans. problems with all of your Touque Mgt. removed?
I had 80% removed, and now I hear a loud "clunk" each time my trans. shifts gears, so I dropped the trans and looked over all innards and stuff looks great....just sounds bad.
Old Aug 23, 2005 | 02:57 PM
JRsilverado's Avatar
No, I haven't had any problems... yet. I've the new tune only for about a week. I did have the 80% removed tune for 10 months before that. I also just had my tranny rebuilt about a month ago.
Old Aug 23, 2005 | 03:05 PM
nonnieselman's Avatar
i have a '00 ECSB 5.3, 3.42's, G80.
hypercrapper
K&N Fipk
255/70/16 liberator allterrains.
mine will spin pretty good from a dead stop up to 30mph.
and will power brake really easy.
but it is probably just the cheap tires. the back ones are pushing to be replaced! i dont get on the interstate if it rains thats just asking for trouble!
Old Aug 23, 2005 | 03:17 PM
StrokerAce03's Avatar
I've done a few brake stands before but I always wondered, what kind of abuse does the rear brakes receive? I'm assuming that the pads wear quicker but could it damage the calipers and rotors?
Old Aug 23, 2005 | 05:20 PM
GMCHammer's Avatar
11 Second Club
I have about 10,000 miles on my stock tranny now with the mods listed below and no Tq Mgt. It will still chirp them in 2nd and still shifts hard (knock on wood ) Only thing I have done is bumped up the line pressure for firmer shift up top and shift a 6200 RPM. BTW when is a good time to change your tranny fluid, I am at 25000 miles.
Old Aug 23, 2005 | 07:43 PM
JERRY2500's Avatar
I only hold the brake to build boost and let it go when i floor it. So there's no wear on the break pad. I know i'm a smart ***.
Old Aug 23, 2005 | 07:59 PM
8ALTNG's Avatar
I use line lock when doing a burn out. When building boost I actually hold the break to the floor and then floor the gas at the same time. At first I could build no boost. But then I did a set of Hawk pads in the rear and now I can break boost it to 9# on street tires. If you are looking for help doing a burnout, get some line locks. Problem solved.
Jordan927
Nov 10, 2015 02:47 AM
Tim94gt
23
Sep 18, 2015 04:51 PM
Noah Burns
Sep 13, 2015 09:28 AM
spooneralmighty
Sep 11, 2015 02:28 PM
Alco
Sep 4, 2015 04:08 PM
