brake torque
Old Aug 20, 2005 | 08:32 PM
gobblergetter's Avatar
Default brake torque
Why will my truck not brake torque?
Old Aug 20, 2005 | 09:55 PM
duwem's Avatar
I assume you mean power stand or brake stand for burnouts???? could be too sticky of tires or your just not giving it enough gas, took me a little time before I got comfortable to hold the gas down till something happened....
Old Aug 20, 2005 | 10:01 PM
F8L Z71's Avatar
Some trucks just won't do it. May be part of abuse mode coupled with a lack of TQ and too much traction.
My MGC 4x4 couldn't do a brake stand for it's life. It would never rev abouve 3k till I would let off the brake and then it would rev higher but then you start moving and getting traciton so it's kind of a waste. LOL
My 4.8L RCSB did it without much trouble but it wasn't a healthy burnout IMO.
Old Aug 20, 2005 | 11:32 PM
litreddevil's Avatar
Banned
A Good Program Would Take Care Of It.it Is In The Pcm And With The Ele Tb It Will Close It Will Not Give U 100 % Throttle.
Old Aug 20, 2005 | 11:34 PM
1FUNZ71's Avatar
14 Second Truck Club
not true. Mine still wont.
Old Aug 20, 2005 | 11:56 PM
Banned
Well I Did Some Work On A 03 Truck The Truck Had A 5.3 And I Could Not Get The Tires To Brake Talk Got A Tune From Thunder And It Was Takeing Care Of After I Coiuld Burn The Tires Off The Rims.
Old Aug 21, 2005 | 12:04 AM
goshawk23's Avatar
Truck addict
my 01 wouldn't do it till i had some tq management removed. and when i changed from 3.42 gears to 3.73 gears it helped a lot.
Old Aug 21, 2005 | 07:53 AM
bart cox's Avatar
Torque management
abuse mode
thats it, remove it with a custom tuned PCM and you'll need new rubber in short order (not to mention a rebuild of your 4L60E not to long after and if you have a G80 that will go bye bye also)
if you want to smoke 'em be prepared to open the wallet in the near future.
Old Aug 21, 2005 | 08:19 AM
JRsilverado's Avatar
When you have 100% of the TM removed, does that take care of the abuse mode or is that something different? I had Allen remove all TM and It's still hard to spin the tires. I have 2 washers in my shift kit and I can't scratch 2nd. I have 3.42s and 285/60/18 GTIIs.
Old Aug 21, 2005 | 09:47 AM
therock's Avatar
Default Did You Guy's Forget About The Rear Brakes?
Some trucks rear brakes come in harder than others too. My 05 having rear drums will do it real easy. I hardly have to press the brake pedal at all.
If your rear calipers are binding you are asking to snap somthing.
