bore out 4.8???
Old Jun 28, 2009 | 04:56 AM
viciousknid's Avatar
Where's the Beef?
Originally Posted by PathfinderJr
umm... 4.8/5.3 blocks can't be bored out to 4", man. period.
just to clarify, LS 5.7's do not have a 4" bore if that's where your hiccup is. They have a 3.89x" bore or somewhere there abouts. 6.0 blocks have a 4.0" bore.
winner
3.904 is the most those 2 blocks can go (which is the bore on an LS1 5.7). Then you have to switch to a 6.0 block for a 4"
Just do a search for MAX BORE
Old Jun 28, 2009 | 05:15 PM
5speedsilverado's Avatar
ok, so if i do a 3.89x bore with the 4.8 crank and 5.7 pistons will it all work out?
Old Jun 28, 2009 | 06:39 PM
PathfinderJr's Avatar
if you bore the block out to 3.905", which is generally regarded as the max bore for these blocks as viciousknid pointed out, and drop in the 4.8L crank, which has a 3.26" stroke, you'd end up with a 312ci engine. Sure it'd be a quick little revver with a larger bore for better breathing, but if you're going through all this machine work, why not stick in the standard 3.62" stroke crank so you can have an iron block LS1?
The only reason I'd ever stick with the short stroke of the 4.8 after doing machine work is with a 6.0 block to make a high revver that can utilize the L92 top-end. And even that is if I get bored with life and have too much money to play with.
Old Jun 28, 2009 | 09:18 PM
ForcedTQ's Avatar
Lightbulb Here's an idea!
Hell, try it with a 3.898 (stock LS1 bore), or 3.905 if the block proves to withstand that bore (get forged pistons, shoot for compression ratio in the 10's- read below to see why), and use the 4.8 crank. Use a set of ARP rod bolts and have the assembly balanced. Then stick a nice set of heads on there that are designed for this medium size bore, don't go to crazy on the valve sizes. That'll be a nice little motor for sure. Then, if you get the itch to have more power down the road, you'll have a motor thats ready for boost. Turbo / Super charge at will! Then you'll be getting the decent fuel mileage that a smaller displacement will offer when cruising around normally, and have a nice breathing power house that will rev to the moon! Good luck,
Old Jun 28, 2009 | 09:37 PM
cause i currently have the 4.8, and i could build an engine with less money then buying a 5.3 crank
cool, so it would make a decent daily driver motor with a good amount of power. and i did foresee a turbo in the future
Old Jun 28, 2009 | 10:21 PM
GMCtrk's Avatar
You can get a 5.3/5.7/6.0 crank for dirt cheap. Why would you ever do all that work for 35+ less cubes is retarded.
Old Jun 28, 2009 | 11:11 PM
dirt track racer 81's Avatar
id buy that 4.8 crank off ya
AdaMax
May 16, 2016 11:35 PM
legerwn
56
Nov 15, 2015 10:21 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
Wolftrk99
Oct 2, 2015 08:17 AM
97_ek
Sep 23, 2015 09:16 PM
