4.8 and 5.3 are identical bore size,just different stroke.
You can safely bore to 5.7 pistons with 5.3 crank and have a 346 cubic inch engine
i have herd that the 4.8 crank allows you to rev higher, so what if i use 5.7 pistons with the 4.8 crank? i was just thinking about a good way to have an angine that could rev up to like 6500 at least, but make ok amount of power
umm... 4.8/5.3 blocks can't be bored out to 4", man. period.
just to clarify, LS 5.7's do not have a 4" bore if that's where your hiccup is. They have a 3.89x" bore or somewhere there abouts. 6.0 blocks have a 4.0" bore.
