blue smoke upon ignition
Old Jul 21, 2006 | 12:11 AM
Default blue smoke upon ignition
alright so after the cam swap and retune and all that the truck runs great and USUALLY starts perfectly. but everyonce in a while ill turn the key it will try to crank and i usually only hold it for a couple seconds and it sounds like its about to start and i pull off. then i try agian immediately when it promptly starts and revvs to about 2000 rpm and quite a but of smoke come from the exhaust. it think its blueish but im not sure. blue or grey. anyways, the two never happen seperately and its not always on the cold start or always on the hot start. i heard that everytime you turn the key on/off it injects some fuel into the cylinder cuz you are supposed to cycle the key on off three or four times when you run out of gas to prime it so when the smoke comes out is it just extra fuel being burned? it also kinda sounds like typical genIII oil consumption problems too but i dont know how many drops of oil makes how much smoke so i wouldnt know how much im losing...anyone?
Old Jul 21, 2006 | 03:44 PM
Gran Patron's Avatar
Most of the time when you see blue smoke it means engine oil has leaked into the cylinder area. Even if it's a minimal leak into the cylinder you'll see the blueish smoke that you described. You might want to check all you're seals and gaskets. If your're seeing black smoke you might be runin' ritch.
Old Jul 21, 2006 | 03:47 PM
How many miles on your truck? Valve guide seal leaks, possibly.
Old Jul 21, 2006 | 05:32 PM
MikeGyver's Avatar
We can only guess at the cause of your smoke if you can only guess at the color.
Old Jul 22, 2006 | 12:23 AM
its bluish gray honestly. definitly not black. i would have to go with more blue than grey though. truck has 85k on it. why would it only puff intermitantly rather than every startup or even during driving? where is the valve guide seal?
Old Jul 22, 2006 | 02:40 AM
The valve seals are what keep oil from going down into the cylinders. They are on each valve stem and can be replaced while still in the motor.
Old Jul 22, 2006 | 02:53 AM
TouchOfEvil04's Avatar
It cab do it every so often because the seals are not GONE but show some wear.So sometimes you have a little oil sitting there sometimes you don't
This is all drunk assumption of course.
Fprgive me bachlor [arty for a close friend tonight.Looking through one eye but still have some knowledge on tap.....ok stop laughing.
Old Jul 22, 2006 | 08:45 AM
how can i replace these? is ti a pretty big ordeal?
OHsixLS3
Nov 21, 2015 10:41 AM
dsbodley
Nov 14, 2015 09:46 PM
redbird555
Sep 30, 2015 09:28 AM
Velocity1
Sep 22, 2015 01:32 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
