biggest cam in stock 6.0
Old Mar 13, 2007 | 06:15 PM
red83's Avatar
From: sneaking in your back door as you leave!/cartersville ga
Default biggest cam in stock 6.0
what is the biggest cams you have been able to squeeze in a lq4, without flycutting the pistons.
Old Mar 13, 2007 | 08:10 PM
Flyer's Avatar
I dunno about physically ... but I think a 233/239 113 would go nice in one.
I'm assuming this is in a 1/2 ton truck or something besides a 3/4 or 1 ton anyways.
Old Mar 13, 2007 | 08:11 PM
red83's Avatar
actually going in a 3400lb z28.
Old Mar 13, 2007 | 09:25 PM
54triton's Avatar
truck here locally has a 600+ lift cam in it but not sure of the exact specs...
Old Mar 13, 2007 | 11:10 PM
02sierraz71_5.3's Avatar
It depends on the ICL, ECL Im sure you can run big durations as long as the piston is far enough away. The bigger problem will be the intake not performing past 5900 if its a truck or 6500 with the ls6. If memory serves me there are several guys with cams in the 236 range with LQ's uncut
BTW: Alot of prostock run cams with intake exhaust angles in the 120 range
Old Mar 13, 2007 | 11:25 PM
YenkoST's Avatar
I just heard a 238/238 in a 6.0L today and its not streetable in my book and that was with some tuning already done to it. It was shaking the tires and everything else. But, if you want the shaking and cammin muscle car sound....go for it.
I would stick to more of a 224/230 or something like that.
Old Mar 13, 2007 | 11:52 PM
dirt track racer 81's Avatar
i gotta 230/226 in my 6.0..i gotta ls1 intake and ported ls1 heads on it though, i plan on upgrading one of these days i feel like messin with my truck again
Old Mar 14, 2007 | 01:56 AM
Quik's Avatar
5 year bitches!
i put a 242/248 608/612 110 in a 11.1 LQ9 no issues...your fine
Old Mar 14, 2007 | 01:58 AM
RandomHero's Avatar
What's wrong with your cam shaking the tires? I thought it was supposed to do that
My cam does that in my 5.3L and I daily drive the **** out of it.
Old Mar 14, 2007 | 06:22 AM
red83's Avatar
im not concerned about streetability issues. it is a weekend only car. as far as the intake i am going with the livernois motorsports stage 3 l92 heads and a carb intake. that should help my upper rpms, and the car is going to see the spray
i was thinking something around a 230 to 240ish dur and .610 lift on a 113 or 114
thanks for the replies . keep them coming
