A bigger cam?
Old Mar 8, 2017 | 02:09 PM
  #71
blsnelling's Avatar
Don't know the specs of the LT1z cam, and based on your wants I see no need to run a 235 exhaust duration of he PCM of nc cam. That's too late of an exhaust close imo for your setup.
What would you recommend?
Old Mar 10, 2017 | 08:40 AM
  #72
blsnelling's Avatar
Originally Posted by madmann26
The BT truck cams have some nice lope/chop, especially that stage4 truck cam.
Originally Posted by blsnelling
For reference...
Brian Tooley Stage 4 Truck Cam
224/230 .553/.547 111+2 +5° overlap
https://www.briantooleyracing.com/tr...ge-iv-cam.html
On the plus side, this cam wouldn't require new springs.
The BTR stage 4 would drive very similar to your current cam only with a rougher idle and a little bit more topend. This is assuming your current cam is a 112+2 for valve event purposes.
I am very intrigued by this cam. It would be a quick, drop in replacement, not even requiring new springs. I'm not sure if the base circle is the same, so would have to check pushrod length.
My only concern is lift. This cam has less lift than my current cam. Is this a concern? Should I ask BTR for a custom grind with more lift?
03sierraslt, my cam is ground straight up with no advance built in.
Old Mar 10, 2017 | 09:10 AM
  #73
03sierraslt's Avatar
With stock heads that little loss of lift won't hurt anything. For stock heads any lift between .550-.585
Couple less won't hurt anything. Any more is a waste.
Old Mar 10, 2017 | 09:26 AM
  #74
blsnelling's Avatar
I'm running hand ported 243 heads. However, I have no idea what they flow.
JordanH
Aug 8, 2015 07:59 PM
Sexyrado327
Aug 2, 2015 04:08 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
black6spdz
Jul 16, 2015 01:32 AM
06 4.8
Jul 14, 2015 08:09 AM
