best way to get low end power
Old Apr 27, 2009 | 12:19 AM
Lifted03Silverado's Avatar
Originally Posted by TX Tahoe Z71
For a low end torque cam, I would go really high lift (that's where you get your torque), maybe .560 or so, like a 212/218 (popular combo here), and a 114 or higher lobe separation to shift the powerband lower and keep the idle nice and smooth.
What if Im wanting something that sounds a tad bit choppy? So its somewhat noticeable theres a cam there
Old Apr 27, 2009 | 01:35 AM
pewterliftedz's Avatar
the choppyness comes from lowering the LSA... the lower ther LSA the shorter and higher your bringing up your power range...
the vinci "trucker cam" is supposed to make awesome torque...
o and by the way have you tried a live tune yet???
Old Apr 27, 2009 | 05:13 AM
PSM's Avatar
PSM
Originally Posted by Lifted03Silverado
what elastic band effect?
Im also wanting the best way to get some low end power. I have 38s and 4.88 gears with a stock cam and stock stall
I dunno how to describe it. When you hit the throttle the engine revs but there is a delay in when the vehicle moves, almost like there is a lot of drive terrain wind up.
Old Apr 27, 2009 | 08:10 AM
viciousknid's Avatar
Where's the Beef?
That's where Circle-D is Awesome. I had a TCI 3000 temporarily and it would do that. Put in a circle D 2800-3200 and it drives like a 2200 while still performing like a 3000 at WOT.
The TCI also gave me an avg of 14mpg with a best of 15 and the Circle D is 16-17.
However I wouldn't recommend a Stall if you want low end, It's just too excessive IMO unless you want something that's just fast.
Get some 4.10's, Small cam, Long Tubes, and a Tune like already mentioned. Don't worry about the MPG difference in the Gears. Im getting the same or slightly better MPG's with those mods than I was getting stock with 3.42s in my Extended Cab.
I noticed the best MPG's by getting a Speed Density tune. Luckily you can do that with EFI Live now without putting in a Custom Operating System. I lean my cruise out to 15.5-16.0AFR and i'm happy with it.
Old Apr 27, 2009 | 12:13 PM
Spoolin's Avatar
GFYS and STFU
Go to the dark side!!
Old Apr 27, 2009 | 12:40 PM
silver-mod-o's Avatar
Hunt&Fisherator
we've got cookies
Old Apr 27, 2009 | 08:42 PM
lukesdad04's Avatar
MGsilverado said in his original post he wanted more bottom end performance so he could smoke the ricers. Anyone who thinks adding a stall converter won't give you better bottom end performance is mistaken. Yes there are some drawbacks but the performance gains are well worth it. Sure adding a small duration high lift cam like the OLD MAN cam will provide more torque and switching to 4:10 gears will help also. However the least expensive easiest way to make your truck take off faster is to add a stall converter.
zblee
63
Jun 10, 2023 01:25 PM
thunder550
Oct 8, 2015 04:53 PM
JordanH
Aug 8, 2015 07:59 PM
OLD BULL
Aug 1, 2015 05:00 PM
Ketis
Jul 23, 2015 12:37 PM
