Best cam for my heavy SUV
This cam going into a 96 2dr Tahoe . I drive this thing on weekend and evenings .. Some track time and more street time then anything.. What cam do you think would be best for the heavy suv(4000 lbs.).. I was think of the Texas speed 228 cam ..
List of mods so far
5.3 bored out to 3.905
Mahle 2relf top piston +4
Eagle h beam rods
42 lbs. injeators
Ls6 intake
317 heads milled .040 = 66cc
Dubl roller timing chain
As of now i have 2400 - 2600 rev max stall
411 gears
.040 head gasket
Not bought yet.
TB
150 shot later
Valve spring
Push rods
Lifters
List of mods so far
Eagle h beam rods
42 lbs. injeators
Ls6 intake
411 gears
.040 head gasket
Not bought yet.
TB
150 shot later
Valve spring
Push rods
Lifters
I think what he means is that it'll move the powerband to the right a bit, giving you a bit less on the low end.
If it does weigh only 4,000lbs, a comp 216/220 or something like a TPS 220.
FWIW: I'm running the 216/220 comp, in a 5,000 lb 4x4 with a 5.3 and had minimal low end loss (also did 243 heads and bumped compression from 9.5 to 9.9) on the stock stall. I think with the bigger cubes, you'll be fine with a low 22x cam.
I personally don't think the LS6 intake will hurt you, it's a good flowing intake in my opinion. If you are really want to keep your low end torque, then go a bit smaller on the cam. The Texas Speed 224/228 cam would be a great compromise. If you are really leaning towards the 228R, I see no reason why it won't work well in a 5.7 motor, especially if it's a playtoy and not a daily driver. Weight is not really that bad, heck my GTO weighs almost that much.
Thank you guys for your help
What do you guys think about this cam.. I am not set on any cam yet..
Comp 54-455-11 Very strong torque and excellent response
