before and after TBSS INTAKE dyno finally
Old Mar 10, 2010 | 11:25 PM
  #61
chevyboy.520's Avatar
i bought a brand new 2010 silverado intake with throttle body, injectors, fuel rails, gaskets and bolts, never been bolted to heads, $250 on ebay. wish i would of read a lil more about the throttle body plug in being different, 8 to 6 pin. i would of ordered a xlink wiring harness at the same time, instead of waiting till it came in, bolting it up and not being able to plug it in. cant wait to see what kind of gains i get.
Old Mar 11, 2010 | 01:12 AM
  #62
Bumpers's Avatar
I will be puttin one of these on my 5.3 here soon hope I get some decent results as well but with my luck it won't do anything on a 5.3
Old Mar 11, 2010 | 12:09 PM
  #63
Bumpers's Avatar
What is everyone using for an intake and connecting to the new larger TB?
i dont think the outside diameter of the stock 78mm is any different than the stoc 87 that comes on these intakes
Old Mar 11, 2010 | 01:55 PM
  #64
TVI's Avatar
TVI
IMO...Find you a set of take-off 243/799 heads from a GMT900 & with your cam it should run really good. FWIW...the TBSS intake manifold was designed for the 243 heads.
Old Mar 11, 2010 | 09:34 PM
  #65
Bumpers's Avatar
I would like to have a set but wouldn't the 243s even off a new motor lower the compression ratio on my motor? they would have to be milled?
Old Mar 11, 2010 | 09:42 PM
  #66
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Im going to use a 90mm edelbrock throttle body, Im almost positive it its larger than the stock throttle body OD.
Yes they will, the new 799(243) headed 5.3s have flat top pistons to keep the CR up. IMO I would never go to the trouble to install a set of heads unless they were ported or I was repairing a problem otherwise its just not worth the money for bolts/gaskets and your time.
Old Mar 11, 2010 | 10:06 PM
  #67
budhayes3's Avatar
PT's Slowest Truck
Will the TBSS intake work with Cathedral port heads? And if they do, would this intake be helpful on say an LQ9 with WCCH StageII 317's and a Trickflow 220/224 .575/.575 112 cam?
Old Mar 11, 2010 | 10:11 PM
  #68
Bumpers's Avatar
Well if I was gunna do heads on my truck I would have them ported... But I was told that the 87mm has the same OD as the 78mm
Old Mar 11, 2010 | 11:07 PM
  #69
hirdlej's Avatar
Yes and Yessssssssssss!
Old Mar 12, 2010 | 09:34 AM
  #70
1slow01Z71's Avatar
No absolutely not, you should get rid of your heads and sell them to me CHEAP
From everything Ive read this seems to be a decent upgrade if you can pick the intake up for cheap enough. For us old school cable throttle guys you can get the edelbrock TB I posted the PN for without the sensors(swap your stockers over) for 260. Im going to try and adapt a set of stock fuel rails over to the TBSS intake. If I can do this for under 400 Ill consider it a success if I see the 15/15 gain thats been posted.
I just got my TBSS intake in the mail yesterday so this weekend Im going to start mocking things up, unfortunately it wont be on for atleast 2 more months since Im moving and got a lot of other things to do
