before and after TBSS INTAKE dyno finally
Old Mar 15, 2010 | 08:57 PM
  #81
Low91's Avatar
Originally Posted by NicD
I'm pretty sure the 90mm car TB has been shown to make less horsepower than the TBSS/truck TB when slapped on the TBSS intake manifold... somebody correct me if I am wrong. If I am not though you may want to offload that car TB and just pickup the truck one.
That would suck seeing as how I just sold a truck TB. The only way I could see that being true was if it had to do with the opposite opening of the blade, other than that 90mm is 90mm no matter how you measure it.
Old Mar 15, 2010 | 09:32 PM
  #82
chevysten's Avatar
Would the tbss intake be any better than the ls6 intake?I know the ls6 cost more.Just curious which of the 2 intakes are better $ per hp.
Old Mar 15, 2010 | 09:51 PM
  #83
007gmc's Avatar
i would like to see a comparison on these too
Old Mar 16, 2010 | 12:12 PM
  #84
NicD's Avatar
9 Second Club
I just swear I remember reading something on a TBSS board about swapping out their factory TB for a car 90mm TB and losing power... something about the blade sweeping the wrong direction and the "vanes" around the edge of the TB swirling the air correctly in relation to the throat angle of the intake manifold. I think the consensus was keep the factory TB if N/A and only use a car TB if in an FI application because it has the stronger springs/motor so it doesn't go into reduced power mode since the TBSS TB is weak and the blade moves too easily with lots of airflow. I know that last part is true though because I have ran into it myself many times and the switched to a car TB to fix the issue. Hell now I am going to go search for that.
Old Mar 16, 2010 | 12:51 PM
  #85
NicD's Avatar
9 Second Club
Found it
http://www.tbssowners.com/forums/showthread.php?t=4799
Old Mar 16, 2010 | 07:01 PM
  #86
007gmc's Avatar
thats crazy, good thing i didnt waste the extra money on a car style tb
Old Mar 16, 2010 | 11:49 PM
  #87
Low91's Avatar
I got to thinking about this last night then looked into the "throat" of the intake. The opening to the runners is in the top of the tube shaped thing in the intake, and with the blade opening oposite than normal its just going to create more of a barrier for airflow. I wonder how an ls2 car or an edelbrock pro-flow intake would work?Oh well lesson learned. Back to ebay for this throttle body unless anybody here needs it.
Old Mar 23, 2010 | 11:21 PM
  #88
007gmc's Avatar
The only part number I can find on these intakes is 12580420 thats good number to the SSR, All V8 Trailblazers 6.0 and 5.3 and works on the new body trucks and suv's with 5.3's. I really have seen no proof on there being to different intakes except for the speculation on one looking wider in a picture than another in a different picture. Btw if the TBSS intake was any wider than my flexfuel motor one I have the fuel rails wouldn't fit over it.
Old Mar 24, 2010 | 07:32 PM
  #89
TVI's Avatar
TVI
FWIW...the Pontiac Grand Am Prototype class originally used the LS6 intake manifold, but switched to the TBSS after they picked around 10HP with it over the LS6. They now use the FAST LSX-RT (truck) intake.
Old Mar 24, 2010 | 07:53 PM
  #90
budhayes3's Avatar
PT's Slowest Truck
I thought that I saw a comparo somewhere where the TBSS intake outperformed the LS6 intake across the board?
