Balancer removal and installation tips ??
Old Mar 13, 2014 | 07:24 PM
BlackRCSB's Avatar
Default Balancer removal and installation tips ??
Okay, springs are about to go in so are the pushrods, tommorow I'm tackling down the cam swap, seems simple only thing that concerns me is the balancer removal and installation -.-
Any helpful tips will be highly appreciated !
Old Mar 13, 2014 | 07:38 PM
greasemykey's Avatar
3 jaw puller will take it off. look on the inside of the hub you will see 3 flat spots. on the install you should use the balancer install tool that is sold by SDPG. a forum member makes them. they are about 60 bucks. there is a measurement that the pulley needs to be off of flush from the crank but I forget how much
Old Mar 13, 2014 | 08:09 PM
I oil up the seal, clean balancer snout and put some anti seize inside, get my propane torch and slowly heat snout of balancer. Slides on like butter! Never damaged or had a leaking seal
Old Mar 13, 2014 | 09:15 PM
Tootall's Avatar
https://www.performancetrucks.net/fo...l-pics-474303/
Old Mar 13, 2014 | 09:34 PM
BlackRCSB's Avatar
Great ideas ! Thanks a lot guys !
Old Mar 13, 2014 | 10:31 PM
dirt track racer 81's Avatar
You can get my balancer install tool from sdpc.com
Old Mar 13, 2014 | 10:33 PM
jmgak47's Avatar
I have one of your tools Tyler, I am going to let him borrow it.
He is in good hands!
zblee
63
Jun 10, 2023 01:25 PM
Three6GMC
Nov 5, 2015 10:02 PM
kr1s
Aug 24, 2015 05:34 PM
