ASP pulley removal - with pics
Old Dec 22, 2010 | 08:16 PM
Tootall's Avatar
Default ASP pulley removal - with pics
Here's a few pics on how to safely remove the pulley with out messing up the crank or the pulley itself
use the old school puller with 3 of the timing cover bolts, thread them in about 1/2 an inch . . . do not use the bolts that come in the kit,
use an extension to put inside of the crank to pivot on. Put some anti-seize or grease or some kind of lube
Old Dec 22, 2010 | 08:30 PM
andrew383's Avatar
traveling mod
Same puller i just used but i couldnt get the m8 bolts to go in so i used 5/16th fine thread...
That did the inside of the pulley look like
Old Jan 5, 2011 | 02:27 PM
Tootall's Avatar
Default stock ballancer removal - stock pulley puller
Here's the stock pulley 99-02 coming off with the Chrysler puller
Old Mar 13, 2014 | 09:14 PM
Tootall's Avatar
- bump - for BlackRCSB
Old Mar 13, 2014 | 09:37 PM
BlackRCSB's Avatar
Thanks ! 👍
Old Mar 13, 2014 | 09:40 PM
BlackRCSB's Avatar
So you slid a 6" extension in place where the pulley bolt came out ?
Old Mar 14, 2014 | 10:24 PM
BlackRCSB's Avatar
I used the Chrysler puller this morning, worked like a champ !
Old Mar 14, 2014 | 10:46 PM
TXsilverado's Avatar
I just roll up my sleeves and give it a good yank. 0% of the time, it works every time...
GXPJAY
Feb 13, 2022 08:15 AM
chacho44
Aug 17, 2015 03:36 AM
Ls3silverado
Jul 31, 2015 04:22 PM
