back to thinking i need some 15" rims
Old Jun 27, 2004 | 10:54 PM
parish8's Avatar
single digit dreamer
Default back to thinking i need some 15" rims
ok, i am back to thinking i need some 15's on my truck. the main reason is there are soo many tire choices in the 15" range.
i can get WIDE 30" tall drag radials from BFG or M/T.
after looking closely at the front of my truck i think a 15 would fit prety easily. the stud from the ball joint could be trimed up easy. up toP there is a sensor wire that might be close but probably be fine. the caliper is kind of close but the rim is extra thick in that area so on most rims i think it would be fine.
the rear looks real tight, the caliper is about 3/8" away for the entire way. who has put 15's on the back of their truck and how hard was it?
does anyone have a 15" rim i can try? thinking something light and simple like some prostars. i'll pay shipping both ways, just want to try it.
imagine 4 315/60/15 bfg drag radials, i bet i would hook like mad with that set up.
Old Jun 27, 2004 | 11:04 PM
Black Blown 02's Avatar
I think that'd be a sweet setup. Then you could keep the 16's for roadtrips or something.
I'll bet you could save 10-15 lbs per wheel also!
Old Jun 27, 2004 | 11:46 PM
Deckhand's Avatar
I've read that you have to grind on the calipers with 15"s..
If i can fit a 15, it would be hell of a lot easier to find a 30" slick.
So far I can only find 28inchers for 16's.
Old Jun 28, 2004 | 12:26 AM
Hit Man X's Avatar
Don't forget Hoosier makes some absurdly wide street ones called "Pro Streets"
http://www.hoosierracingtire.com/strttire.htm
They are 29 to 31" tall and 12-18" wide. 15 to 17" rims also...
Old Jun 28, 2004 | 12:31 AM
parish8's Avatar
the first hoosier in a 16" is way too wide. they have a nice 31-12.50 in a 15 though. all the good sizes are for 15" rims
i dont mind grinding if it is posiable to make it work.
Old Jun 28, 2004 | 12:37 AM
Hit Man X's Avatar
Could you run a 15" on the front and a 16" on the back? Or are you wanting the same height for each shoe?
Like a 31x12.5x15 up front and a 31x16.5x16 out back...
Old Jun 28, 2004 | 12:40 AM
parish8's Avatar
i would really like to have 4 of the same rim/tires that way there would be no problems with the 4wd stuff, i could warm the rears and then rotate when they started to get worn.
Old Jun 28, 2004 | 12:41 AM
Deckhand's Avatar
parish, hoosier makes the quick time pros for a 16", 28inches tall, and 10inches of tread on the floor.
Old Jun 28, 2004 | 12:45 AM
Hit Man X's Avatar
Ah okay...well perhaps that 12.5 would work best as it should fit front and rear fine.
Old Jun 28, 2004 | 12:52 AM
Mr. Sandog's Avatar
You have to admit, these are some serious luxury problems...
