Attn: NewFrontMount Turbo requires a helmet!
#41
Do you take kidney's in on trade? How about a partial liver transplant? If not, it's going to take me roughly a year and a half of trips to donate sperm and plasma twice weekly... Sure, I may be a little tired after vending my bodily fluids, but I'll have me a turbo!!!
#42
Sorry no organ trade ins allowed. lol heres a link where I post what the parts will look like coated.
https://www.performancetrucks.net/fo...d.php?t=381678
#44
Performance Trucks Sponsor
Originally Posted by Snake Eater
so if I'm running 15.6's I could be in the 12's easily with this kit at low boost? If i just had a stall and did better than 2.4 60' maybe i would be in the 14's N/A, and mid 12's with boost?
I'd say a big truck like that would drop at least 2secs.
allen
#46
Originally Posted by mabutler
What all is included in the kit?
Turbonetics 62-1 turbocharger, with a 0.81 A/R turbine housing for fast spool
Turbosmart 38mm waste gate
Turbosmart 25mm Sleeper Series bypass valve
Stainless steel flanges, 3/8 thick.
Stainless steel turbo manifold with 1.625 diameter primary tubes.
2.5 diameter crossover pipe with flex coupler, prevents stress cracking
3.0 diameter downpipe
Stainless steel flex joint connection for the wastegate, prevents stress cracking
K&N cone-style air filter, 4 diameter by 5 long
10 ft of Ύ heater hose and clamps
Heat shielding for air conditioning line
1 tube of Copper Seal high temperature silicone sealant
3.0 diameter stainless steel charge piping
Silicone 90 degree coupler for turbocharger connection to charge pipe connection
Silicone 90 degree coupler for charge pipe to throttle body connection
Silicone coupler for MAF to charge pipe connection
6 stainless steel T-bolt clamps for silicone couplers
All mounting hardware, nuts & bolts
Oil feed line (-3 AN)
Oil return line (-8 AN)
Oil return fitting for the oil pan (-8 AN)
Drill and tap for oil pan fitting installation
Introductory price of the INTRO kit for LS1Tech members is
$4054.00.
** Upgrade to a Turbonetics T-76 Q trim add $500.00
*** Upgrade to an Air/Water Intercooler add $1400.00
#47
damn that sounds like a sweet deal. What about air/air intercoolers? I sure hope i get this higher paying job soon, the toys keep getting better and better. Before long the average truck will be running 11's, and the "slow" trucks will be those low 13 sec ones.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
yellow2000S/R
Mar 12, 2016 04:33 AM
FlowmasterMufflers
Aug 31, 2015 05:11 PM
