ATI Procharger
Old Sep 8, 2003 | 08:37 PM
Smoky02's Avatar
Default ATI Procharger
Aight this is the deal, right now I'm running on a stock 4.8, but I plan on building a 408 stroker motor. Should I buy the procharger now, use it on my stoke motor and then after I build the new one have a sure enough bad a$$ ride? Or would the ATI procharger not be very good on a stock 4.8??
Old Sep 8, 2003 | 08:39 PM
Deckhand's Avatar
Default Re: ATI Procharger
I would like to know as well, I have a 4.8 and ASM Longtubes are in the mail. Eaton posi w/ 4.10's are on my list also. TIA.
Old Sep 8, 2003 | 09:35 PM
Got a guy here with a 4.8 and procharger at the track, running 13.4s at 2000 ft elevation in 90+ weather. So Oh yeah, you can run! his is a SC/SB though!
Old Sep 8, 2003 | 09:59 PM
GMC SKI's Avatar
Go ahead and get the Blower If your plannning on building the Kit for for bigger motor
I would say just But the Blower and blower braket
make your own intercooler and buy yourself a a gss340 Inline fuel pump some Larger injectors
and a copy of ls1 edit
You'll Save some Cash on the kit buy buying just what you need
Get at least a D1-sc head unit or even an F1 unit for the 408 motor
jim
Old Sep 8, 2003 | 11:37 PM
tbyrne's Avatar
The head unit alone is about $2100. To do a custom kit is may be cheaper to buy the complete system and sell what you don't need. I would at least go with the D-1SC to feed the stroker. The kit would also work on the stock motor. The head unit upgrade is usually recommended if the motor has been modified (headers/exhaust for example) or if you are at a high elevation. Your a pulley swap away from more boost in the future.
Old Sep 9, 2003 | 03:53 PM
Smoky02's Avatar
I appreciate the info, is the intercooler that comes with the kit not efficient enough? It comes with a 2-core, I was just going to use that, on both motors...
Old Sep 9, 2003 | 09:51 PM
GMC SKI's Avatar
If you going to Feed that monster engine
You'll need a larger cooler for sure
You will Gain in my guess 1-2lbs of boost Because of the location and size of the stock cooler
that's why I'm making my own
Jim
Old Sep 9, 2003 | 10:05 PM
Smoky02's Avatar
It's gonna be a while before I get to chance to finish the monster, exactly what all am I going to need on the stock engine??
Old Sep 10, 2003 | 10:02 PM
MarineBlue03GMC's Avatar
Tech Fanatic
Hey tbyrne just wanted to let you know that your "tbyrne" link posted in your sig is not working.
madmann26
Apr 29, 2020 09:17 AM
murderedSS
Sep 27, 2015 10:16 PM
MOBBN
Sep 22, 2015 08:07 PM
murderedSS
Sep 22, 2015 03:53 AM
Justin87gn
Sep 10, 2015 12:06 PM
