ASP Pulley's
Old Feb 2, 2005 | 07:32 AM
BLACKHD01's Avatar
Default ASP Pulley's
I have heard that when you change out pulley's that you have to change out the harmonic balancer bolt. Does anyone know what the OEM part number is for the bolt? I have heard that some people reuse their old bolt, and it works fine, anyone done this?
Thanks,
Jason
Old Feb 2, 2005 | 07:57 AM
6gear's Avatar
Thanks,
Jason
I bought a new bolt the first time I made the swap but since then I have done it again and used the stock bolt with no problems
Old Feb 2, 2005 | 11:21 AM
BADMOFO's Avatar
Cuz I AM a BADMOFO
I wouldn't re-use the stock TTY (torque to yield) bolt over. They do however have an ARP brand re-usable bolt. I would just get a new factory bolt if I were you. They are very inexpensive (less than $5) and well worth the piece of mind. Here is a link to what "others" have said in the past.
https://ls1tech.com/forums/showthrea...ey+bolt+torque
Old Feb 2, 2005 | 11:34 AM
goshawk23's Avatar
Truck addict
yea it isn't that expensive to buy a new gm bolt. just extra insurance.
Old Feb 2, 2005 | 03:53 PM
BLACKHD01's Avatar
Thanks for the info guys, looks like I will just get a new bolt.
Old Feb 2, 2005 | 03:58 PM
GREGGO's Avatar
****, I've taken mine off at least 5 times, it will be fine. Although I did have to borrow goshhawk23's socket at Thunder last year to tighten mine back up LOL!!!! Not that the pulley moved or anything, just stuck my hand down ther since I had just swaped the cam a few days earlier to check it. If you don't use a new bolt, you may have that problem, but if you reuse the one you have, be sure to check it like I do.
Old Feb 2, 2005 | 04:08 PM
I have done several pulley installs reusing the bolt. I have checked the torque after use and it has never changed.
Old Feb 2, 2005 | 05:42 PM
qwank's Avatar
just put a little blue loc-tite on the bolt and it won't losen up. i reused mine.
Vortec350ss
Jan 12, 2016 10:36 PM
wickedRCSB
Oct 30, 2015 09:45 PM
Lthompson
Oct 2, 2015 12:45 AM
old motorhead
Sep 29, 2015 08:22 PM
murderedSS
Sep 27, 2015 10:16 PM
