Anyone with a predator? HELP!!!
Old Jul 23, 2003 | 04:04 PM
954RR's Avatar
Default Anyone with a predator? HELP!!!
Ok downloaded a "revised custom program" from James at running with the devil to my predator. Went to install it into truck and it downloaded only 70% of it. I start download again and it downloads 4% so I tried it again and it says " no response from PCM. is ignition on?" well of course it is on!! so i tried it multiple times and it does the same thing. Even re-downloaded the program on my predator from my computer..... and unhooked my battery cable for 15 minutes and still no dice. Not to metion truck won't start!! I think i might be sick He said I might have to ship the PCM to him so he can look at it. Anyone with any suggestions would be greatly appreciated!!
Old Jul 23, 2003 | 05:00 PM
11 Second Club
Default Re: Anyone with a predator? HELP!!!
You need to have your PCM flashed. The dealer can do it for you. Send the predator back and they can flash it or do what ever it is that they do to get it functional again.
Old Jul 23, 2003 | 05:20 PM
954RR's Avatar
thanks a bunch.... i will try that. Wonder what makes a PCM crash like that?
Old Jul 23, 2003 | 07:36 PM
RED2K's Avatar
Go into and do the saved data program. Then try it and take about 15 seconds in between steps. As in after it finishes one thing wait 15 seconds before you try it again. It happened to me before as well. Load your saved data and then send it back.
Old Jul 23, 2003 | 09:41 PM
954RR's Avatar
I can't get to the "saved data program" That requires communication between my PCM and the predator and the predator (when i go into the tune section) just gives me a "no response. Is ignition on?"
Old Jul 23, 2003 | 09:44 PM
11 Second Club
I had a Hypercrap do that to me, I had to have my computer flashed back to stock.
Old Jul 23, 2003 | 09:51 PM
954RR's Avatar
Ya my truck is under an extended warrenty...Hopefully it won't cost anything to get it reflashed, but who knows. Better than not moving Would warrenty cover it or should i just keep my mouth shut and say "It just wouldn't start"
Old Jul 23, 2003 | 10:22 PM
I just Fried mine the last week, did the same thing. They could not reflash the computer at the dealership, so new computer I got, $411.28
I accidently turned off the ignition while it was programming, I don't know what the hell I was thinking. My friend fried his, and they were able to reprogram his with a flash from the factory. When I computers mess up, the predator has to have the ignition on to work, to identify the vin, and it is part of the reprogramming setup. When the computer messes up, it deactivates the ignition. The programmer that they use at the dealerships doesn't need the ignition on, so they can reflash it to a factory setting. They charged my friend $65 for the reflash since they have a one hour minimum labor at the dealership!
Old Jul 23, 2003 | 10:51 PM
954RR's Avatar
Ok so does a GM dealership have to flash it or can a autodiagnostics place do it. I am having it towed in the morning to a place so they can look at it.
thanks a bunch for all the replies!!
Old Jul 24, 2003 | 01:33 AM
Procharged LM7's Avatar
My superchimps did the same thing, but I didn't turn off jack. BTW superchimps suck big ones for their handling, and knowledge of PCM's, in my situation.
