any reason to buy roller tip rockers
Old Feb 21, 2008 | 11:05 PM
Dark Halo's Avatar
Default any reason to buy roller tip rockers
Just wonder if there is anyreason to run roller tip rockers over stock? I have to stay with the 1.7 due to the tr224 cam I will be getting. Motor will be a 5.3 punched to a 5.7
Old Feb 24, 2008 | 01:26 AM
454SuperSport's Avatar
nope, stock works just fine. won't see a gain with aftermarket rockers so save that money
Old Feb 24, 2008 | 05:59 AM
sickREDsierra's Avatar
arent the stocker a stamped steel body with roller tips already?
no gains from doing the swap. you would most likely have to run a valve cover spacer if you swapped also, as most aftermarket full roller rockers are taller than stockers, and wont clear the valve covers.
Old Feb 24, 2008 | 12:11 PM
Dark Halo's Avatar
no they are a roller body but not a roller tip.
Old Feb 24, 2008 | 12:12 PM
Dark Halo's Avatar
Cool I did not know if the roller tip would provide any benifit
Old Feb 24, 2008 | 03:42 PM
jkwalkercchs's Avatar
yes they will if u are turning big numbers
but theres fbody guys running 9s on stockers
Old Feb 24, 2008 | 04:31 PM
Dark Halo's Avatar
I do not think I will be running 9's any time soon lol
Old Feb 24, 2008 | 05:28 PM
Wilde Racing's Avatar
How do I change this text
Comp claims 10 hp gain with reduced friction...
Old Feb 26, 2008 | 01:15 AM
06chevy5.3's Avatar
I just bought some comp 1.85s to bump the lift on my cam up there designed to fit under stock covers the engine shop i bought them from told me il some increase beacuse they lighten up the valve train and reduce friction VHP claims 25rwp average increase with theres
Old Feb 26, 2008 | 07:51 AM
WELL, DOESNT RPM OUTLET CLAIM 12 HP WITH A THROTTLE BODY SPACER, AND ANOTHER 15 HP WITH SOME PLUG WIRES?
