any reason to buy roller tip rockers
Just wonder if there is anyreason to run roller tip rockers over stock? I have to stay with the 1.7 due to the tr224 cam I will be getting. Motor will be a 5.3 punched to a 5.7
nope, stock works just fine. won't see a gain with aftermarket rockers so save that money :D
arent the stocker a stamped steel body with roller tips already?
no gains from doing the swap. you would most likely have to run a valve cover spacer if you swapped also, as most aftermarket full roller rockers are taller than stockers, and wont clear the valve covers. |
Originally Posted by sickREDsierra
(Post 3856520)
Originally Posted by 454SuperSport
(Post 3856495)
Originally Posted by Dark Halo
(Post 3856688)
Cool I did not know if the roller tip would provide any benifit
but theres fbody guys running 9s on stockers |
Originally Posted by jkwalkercchs
(Post 3856856)
yes they will if u are turning big numbers
Comp claims 10 hp gain with reduced friction...
I just bought some comp 1.85s to bump the lift on my cam up there designed to fit under stock covers the engine shop i bought them from told me il some increase beacuse they lighten up the valve train and reduce friction VHP claims 25rwp average increase with theres
Originally Posted by 06chevy5.3
(Post 3858345)
