Any other 6.0's with low oil psi??
8 second mod
I have an 03 2500 hd with a 6.0
seems like my oil press is a tad low, i drove my buddy 5.3 the other day, and his was up there, im just a tad under 40 at idle. i have 30k miles on it and have towed alot, it seems to run around 50-60 under accel, but not sure if the oil pumps are issues in this truck. she has piston slap to, i ran moble1 5 30, then i read with pistion slap to run 3 qt's 5-30 and 3 qt's 10-30, so moble 1 mix is what i run now.
what do you think? think its all good? the truck is pretty much stock, but will be getting sts soon
I have an SS (LQ9) 6.0, and mine runs a tad under 40 at idle too, always has. It has 5000 miles on it. It did it with 5w30, and same with 10w30 which is what is in it now. M accel psi's seem to be about the same i think, mabye a bit higher because i am using full 6 quarts of 10w30. I hit 80 psi at the shift points at wot.
Nate
Nate
05GMC4.8
Aug 7, 2015 09:55 PM
Ferocity02
Jul 17, 2015 07:05 PM
