Any other 6.0's with low oil psi??
Old Dec 20, 2004 | 07:56 AM
Noyzee's Avatar
8 second mod
Default Any other 6.0's with low oil psi??
I have an 03 2500 hd with a 6.0
seems like my oil press is a tad low, i drove my buddy 5.3 the other day, and his was up there, im just a tad under 40 at idle. i have 30k miles on it and have towed alot, it seems to run around 50-60 under accel, but not sure if the oil pumps are issues in this truck. she has piston slap to, i ran moble1 5 30, then i read with pistion slap to run 3 qt's 5-30 and 3 qt's 10-30, so moble 1 mix is what i run now.
what do you think? think its all good? the truck is pretty much stock, but will be getting sts soon
Old Dec 20, 2004 | 08:00 AM
NateZ's Avatar
I have an SS (LQ9) 6.0, and mine runs a tad under 40 at idle too, always has. It has 5000 miles on it. It did it with 5w30, and same with 10w30 which is what is in it now. M accel psi's seem to be about the same i think, mabye a bit higher because i am using full 6 quarts of 10w30. I hit 80 psi at the shift points at wot.
Nate
Old Dec 20, 2004 | 08:06 AM
procharged hd's Avatar
i think you will be fine mine is alittle higher ,but i also run 10-30 oil
Old Dec 20, 2004 | 10:24 AM
marc_w's Avatar
Mine's alway been at like, 35 at idle, and just over 45 when I'm driving. (40 is the middle marker, right??)
Old Dec 20, 2004 | 12:12 PM
Noyzee's Avatar
8 second mod
yes.
thats good to know. thanks
Old Dec 20, 2004 | 03:40 PM
bud8fan's Avatar
sounds like its ok...mine runs the same..
Old Dec 20, 2004 | 05:45 PM
mattrem's Avatar
I thought mine was low, but it is the same as you guys around 38 at idle. I was thought about changing the pump when I swap the cam. I quess it is ok. I use Mobil 1 5w30.
Old Dec 21, 2004 | 07:38 AM
Noyzee's Avatar
8 second mod
thinking about a ported pump when i do my sts, but who knows, it makes me feel beter about the oil issue tho. thanks
JordanH
Aug 8, 2015 07:59 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Ferocity02
Jul 17, 2015 07:05 PM
Mzay
Jul 6, 2015 11:03 PM
