Another DC-Control user.
Old May 29, 2004 | 08:05 PM
marc_w's Avatar
Default Another DC-Control user.
I got my 282's installed and wired up with my DCC (dccontrol) unit.
I mounted the DCC unit facing the firewall, under the fender brace, on the fuse box lower housing. The kit comes with plenty of parts, a healthy amount of wire, an enough for the temp probe to reach the other side of my 34" radiator from that location. Wire is 10G high quality large strand copper. I may have been missing a part from my kit (a fuseable link?), so I used the F-a-L 40A fuse. I'll report back about this later.
I have mine set to turn on at 194*F, because I'm running a stock thermostat for now. (the temp is set via jumpers, FYI). Once the preset temp is reached, it takes nothing more than 3-4V output at the terminals, for about five to ten seconds, to cool the motor. I'd estimate the fans are at 25% _at the most_. Probably more like 10%. It's hard to hear the fans in the engine bay, nevermind inside the truck. Very soft turn on.
When the AC comes on, the fans kick on at 50%. You can "notice" them running inside the truck. At my 600rpm idle (no UD pulley), I see a slight tug on the in dash volt-meter. Like one bar. If rmp's are over 1K or so, there is no noticeable drop. I didn't measure the voltage across the output terminals, but dccontrol.com says it's 8V.
Old May 29, 2004 | 08:23 PM
Hit Man X's Avatar
Very nice! Where could I get a 40A fuse holder and fuse? No luck around here...
Old May 29, 2004 | 08:47 PM
where did you get your dc controller?
Old May 29, 2004 | 08:56 PM
Hit Man X's Avatar
www.dccontrol.com
Old May 29, 2004 | 11:31 PM
one03sierra's Avatar
Formerly one92rs
Talking
cool im glad they worked out for you. im really liking mine.
Old May 29, 2004 | 11:39 PM
Did you guys get the 35 or 60 amp model?
Old May 29, 2004 | 11:50 PM
Formerly one92rs
Talking
hey benkey i got the 60 amp one.they will tell you the 35 amp will work but i am takin no chances
Old May 30, 2004 | 12:01 AM
MacADaYear's Avatar
I went to a car audio shop and they have em. They are used alot for that stuff. Just get a big beefy one and use a 40amp
Old May 30, 2004 | 01:50 AM
Flyer's Avatar
What's the lowest temperature you can set it at ?
Old May 30, 2004 | 08:12 AM
Formerly one92rs
Talking
well i think mine has a setting for like 140. remember it goes on the opposite side of the radiater than the vsc pos.
