Another 4.8 Bites The Dust!!!!!!!!!!
Old Jan 6, 2005 | 11:06 AM
  #51
Flyer's Avatar
Originally Posted by TigerFan187
Yes it was the first tune for the cam. I didnt have a traditional WOT switch I have a TPS switch. It is all electric-supposodly the more you press the pedal the more volts it puts off and the TPS switch is activated when it reaches the volts you set it to open at.
Was it hooked up at the throttle body?
  #52
Flyer's Avatar
Originally Posted by CRAZYCUTER4.8
my chi broke the truck, I have an energy within me that can impose harm on anything.
I believe that one ....
*not to self* Next time you start heating bottles .... RUN
Old Jan 6, 2005 | 11:16 AM
  #53
You would be sooo proud of me I just bought a bottle heater
Old Jan 6, 2005 | 11:41 AM
  #54
TigerFan187's Avatar
No it hooks up to one of the wire on the pcm harness. Here is a link to the one I have. http://www.nitrousoutlet.com/outlet/...&section_id=26
Since we have the electronic throttle body this is all we can use for a "WOT Switch".
Old Jan 6, 2005 | 11:52 AM
  #55
smooth sierra's Avatar
did you guys ever use a bore scope and take a peak down in the cylinder? I would have thought your service manager buddy would have access to a bore scope that could have answered all your questions long ago. I personally believe you broke a piston spraying and it finally let go, but you can check the other thread and get more info on that. Next time run a bore scope down the spark plug hole and take a peak. If you broke a piston you will know it. No one can 'listen' or 'feel' what is broken internally. you have to inspect it. Good luck and hard lesson learned I guess. that misfire you spoke of could have been a piece of a ring banging around in there and getting hot and pre-igniting fuel. just a thought been there done that, but I don't run a service dept. so what do I know. BTW I bet your excessive lean condition was caused when the piston actually let go. But once again I do not run a service dept
Old Jan 6, 2005 | 12:07 PM
  #56
My buddy doesnt do anywork on my truck. I dont think he said he ran a serivce department either but I guess people arent titled to opinions! LOL! Half of your post was talking **** about someone. Just because he used a TECH-2 on my truck doesnt mean anything but he used a TECH-2 on my truck. The place that does the work on my truck B&M Racing did the cam job(springs,rods,new TR-6's,160 stat) and is now dropping the LS1 in. When they put the cam and **** in the slight knocking went away-but that was just luck right? When he put the cam in if he thought there was more damage beleive me he would have told me being another frined of mine. The necessary steps were taken at that time.-That was two weeks ago and all was fine untill the other day! And a misfire is a under statement!
Old Jan 6, 2005 | 12:33 PM
  #57
Flyer's Avatar
Did it lean out up high ... around 5700 rpms or so?
Old Jan 6, 2005 | 12:59 PM
  #58
Yes it leaned out up high! Remember I wasnt spraying either!
Old Jan 6, 2005 | 04:33 PM
  #59
get some friends with a bore scope. your buddy crazycuter told me he was a manager. check the other thread. here is his quote right here
As for me, well you probably should not listen to me either, I am just some stupid manager @ a chevrolet dealership
I also suggested you try a bore scope in that thread. amazing with all the knowledge you have amongst your friends no one did a leak down or ran a bore scope down the spark plug hole. oh well no skin off my back
Old Jan 6, 2005 | 05:28 PM
  #60
vanillagorilla's Avatar
Stop your whining, you're getting an LS1!!! JK
Do you have any pics of the 4.8 shortblock? What did the #3 piston look like, how did the head get damaged? I'm just want to see the carnage. It might help prevent me from spraying my 4.8.
