am i going to lose power? please help me.
i recently straight piped my cats on my avalanche and i am not a fan of the new sound... however im glad i did cause my stock cats were beat and to my suprise one of them was busted up...
i do plan on doing a front mount turbo this winter/ spring and am going to run a catalytic converter with that system... i dont wanna have problems with visual inspection nor the cops here in NY... not to mention the truck smells terrible now lol...
so what im asking is... is a magnaflow 3 inch in&out spun single cat more restrictive than 2 stock converters? it seems to make sense that 2 cats are more restrictive than one... however the summit tech guy tells me different... any ideas guys? would the sound be different than 2 stock converters? hopefully it would be better than it is now... please help me out guys and point me in the right direction. I dont really wanna buy 2 cats that im not gonna use a couple months from now if i can just get one that i will use later also.
well after some research i have found the turbos and cats on these trucks just dont seem to like each other! i do know that a turbo will muffle the sound alot also, however i need to do something till then... this sucks cause i LOVED my borla xr-1 sound i just wanted a tad more of a raw sound like the new camaros have with the xr-1... will a cherry bomb before the muffler help make me not obnoxious anymore? should i just suck it up and get 2 high flow cats? should i get 1 high flow cat? i dont know... but im kinda sweatin bullets here about what to do...
Dang give us more than 2 hours for a response
If you wanna run cat i think you can get American Racing cats that come on there headers along with the magnaflow..
Also silconintakes dot com sells a "free flow" cat lol... You could run one of those and a smaller magnaflow bullit to tame the rasp..
sorry for me being pushy guys... i need a solution to the obnoxious rasp... before the wife hears the truck... LOLOLOLOLOL thats pathedic..
okay after even more research i found alot of people that get longtubes with ORY's and run a metallic spun cat. i have also seen people use the dynomax bullet before the muffler also...
my goal is to go a tad down the volume and eliminate light throttle rasp and almost no drone on highway... i dont mind hell breaking loose at WOT though!!!!! so will a dynomax bullet do the trick or maybe a bit longer cherry bomb? what about case length im thinking about 18 inch case? or a single metallic spun cat? i guess i can get over the smell if i can get rid of the rasp with a bullet or a cherry bomb
nope... got to much money wrapped up in my cat back from the custom bent stainless pipe, xr-1 and 80 dollar double outlet, double wall tip... and i love my XR-1, just need to clean it up a bit from lack of kitties
any insight to my last post KING?
Usually a bullet will help resolve that rasp that you are having. I recently installed long tubes with the ORY. I installed a knock of single chamber flow with a turn down and it actually isnt bad at all. At idle its deep and mellow and little to no drone while cruising. Smack it and all hell breaks loose. Just a little insight.
