Aluminum rockers?
Old Mar 11, 2005 | 08:44 PM
Default Aluminum rockers?
Well my 6.0 swap is almost completed. today I installed the comp 918 springs and found out that the rockers are made of aluminum rather than steel. Can anyone confirm that the rockers are indeed aluminum on the 6.0L. I know the ones on the 5.3 were steel. Are the aluminum ones durable!
Old Mar 12, 2005 | 12:22 AM
mattrem's Avatar
I am pretty sure they are the same rockers. There is no real gain from aftermarket rockers, there are LS1 guys running big numbers with the stock rockers. Yes they will hold up.
Old Mar 12, 2005 | 06:03 PM
Thanks. I was a little surprised because they look aluminum die cast. Aluminum die castings fail with high cycle fatigue. Anyone else have good luck with stock aluminum rockers. Please let us know.
Old Mar 13, 2005 | 07:54 PM
litreddevil's Avatar
Banned
the stock rockers are good and strong the only reason i want different rockers is i am putting solid lifters,so i don't have valve float any more. it would be to hard to shim the stock rockers to set .005 gap in valve stem to rocker
Old Mar 13, 2005 | 08:02 PM
gonzo 6.2's Avatar
When will you fire it up?All gen3 rockers are the same.
Old Mar 13, 2005 | 09:17 PM
I will fire up tomorrow and cant wait. I made a mistake earler; the Gen 3 rockers are investment cast steel. The rockers on the 5.3 were stamped steel
Old Mar 13, 2005 | 09:21 PM
gonzo 6.2's Avatar
If your saying there is more than 1 rocker for the Gen3 engine i want to here what your saying.theres only one as far as i know.
Old Mar 14, 2005 | 08:33 AM
marc_w's Avatar
I just wanted to note, the stock rockers are inefficient when it comes to translating duration from the cam lobe...
VHP/Crane rocker tech info.
I'll check out my factory rockers tonight and see what they're made of. I honestly don't remember right now.
I would think that they're steel - with the "non roller tip" (for lack of better wording) that rides on the valve stem, I would imagine that Al would wear fairly quickly.
Old Mar 17, 2005 | 06:08 PM
I went back to check the 5.3 & you were right, they were also investment cast steel. What was I thinkin?
natejk
Nov 15, 2016 08:05 AM
KINGCYCLES
Oct 2, 2015 10:21 AM
redbird555
Sep 30, 2015 09:28 AM
tim wellington
Sep 29, 2015 10:17 PM
old motorhead
Sep 29, 2015 08:22 PM
