About to order cam...is this the right tools im looking for
Old Apr 10, 2014 | 06:19 PM
Wrecker 426's Avatar
Default About to order cam...is this the right tools im looking for
so two weeks ago i got the TT3000 in to start getting it set up for a cam, and about to order the tsp 224r and single spring and prod package.
Just wondering if this is the right spring depressor
dual sprin press
And compressor hook up to hold the valves
compression check
1999 ecsb 5.3L
thanks
Old Apr 10, 2014 | 07:08 PM
Chevy_King1500's Avatar
those will work, you will need a balancer install tool as well
Old Apr 10, 2014 | 07:17 PM
can you just rent one of those from autozone or is that something special?
how about this though while im at it
puller for h damp
also am i going ot have to run a zinc additive
Old Apr 10, 2014 | 07:20 PM
https://sdparts.com/details/scoggin-...-center/sd6628
are you installing this is your truck with 210k miles?
im not sure on the zinc addictive, i just run synthetic oil.
Old Apr 10, 2014 | 07:43 PM
Yup!!! 213000 now. I run full AMSOIL synthetics. I know it's a lot of miles, I plan on building a 395 stoker after this next deployment this winter, so i will use the cam in there also. And not to worried if i blow up this engine, as i have a plan in place already to replace it and have a bike to ride during the build. Not that I have the money to build it now I just want the power.
Thanks for the link never thought about that step I thought u ment puller
A bit dirty but it's nice to have power in the sand
Old Apr 10, 2014 | 10:23 PM
MustangPunk's Avatar
puller for h damp
That one wont work as theres no spots for the bolts to go in on the balancer to pull it. The remover and installers I got from autozone wouldn't work... I ended making a big 3 jaw pulley puller work for removal, put a extension in the crank threads to keep them from getting mashed up. To install I just used light taps from a rubber mallet to start the balancer on straight, then a big socket over the end with a extension and slowly (beat)tapped it back on. Then tightened the bolts on the timing cover once the balancer centered it
Old Apr 10, 2014 | 10:56 PM
so your saying something like this then?
puller
it didn't throw the balancer off and no wobbles when you did that?
Old Apr 11, 2014 | 05:06 PM
puller
That one will work if it's big enough, I used one that looked like these, I used a decent size one.
Pullers
No wobbles or anything wrong, just made sure I started it on straight as possible and was careful, it's going to take some force to install a balancer slanted IMO..
JordanH
Oct 3, 2015 03:59 PM
Velocity1
Oct 2, 2015 08:01 AM
91LT16SpeedFormula
Oct 1, 2015 08:57 AM
sTNT971
Sep 26, 2015 04:22 PM
