6.0L swap
Old Dec 2, 2005 | 01:14 AM
6.0caddy's Avatar
Default 6.0L swap
I am swaping a 6.0L into my truck which has a 5.3 right now. I want to know if i need to keep my 5.3L intake, injectors, and wiring harness. Or can i use all the parts wiring from the 6.0L, which is out of a denail. Also do i need to use my PCM or the denails PCM ( computer).I have a 4L60e also. 4WD Thanx
Old Dec 2, 2005 | 01:23 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Use the wiring harness off the 5.3 use the intake injectors from the denali cause you have a 99 right? Are you getting it custom tuned?
Old Dec 2, 2005 | 09:44 AM
6.0caddy's Avatar
hey i am getting it professional tune and dyno. Yeah its a 99. so i use my old PCM?
Old Dec 2, 2005 | 09:48 AM
ZDEN's Avatar
if you are getting it tuned and have access to the denali pcm you could use it. most here with 99's have upgraded to an 02 pcm and injectors. maybe one of them will chime in with more info.
Old Dec 2, 2005 | 10:20 AM
6.0caddy's Avatar
well it run if i used eather my PCM or Denali?
Old Dec 2, 2005 | 03:38 PM
budhayes3's Avatar
PT's Slowest Truck
It should run with your PCM, but very poorly. You'll probably be able to drive it to the place that's doing the tuning, but you're gonna want to do the 02 PCM upgrade for sure and use the Denali injectors. (Do a search on 99-02 PCM and you should find a wealth of info) Not sure if the Denali PCM will work...not sure if they're drive by wire and what trans they have
Old Dec 2, 2005 | 03:54 PM
gonzo 6.2's Avatar
I would say "maybe" you will be able to use it.What year is it what is the last 3 numbers on that PCM?
Old Dec 2, 2005 | 04:35 PM
6.0caddy's Avatar
the denali is an 01 not sure on the numbers on the PCM
Old Dec 2, 2005 | 04:38 PM
gonzo 6.2's Avatar
Let us know when you do.
Old Dec 2, 2005 | 06:03 PM
99Silver6.0's Avatar
Use the Denali if you have a 99 PCM.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
ARC
57
Feb 21, 2022 10:54 AM
2500ZL1
Jan 25, 2016 06:30 AM
Denali08
Aug 9, 2015 04:34 PM
oharajo
Jul 18, 2015 09:24 PM
