6.0l build help
Old Nov 16, 2008 | 07:39 PM
  #21
budhayes3's Avatar
PT's Slowest Truck
Yea, your intake and accessories will all swap right over
Old Nov 16, 2008 | 07:46 PM
  #22
lo&sloSierra's Avatar
sweet deal, now i just have to make my mind up on whether or not i want to run a bigger crank, if i do so will i still be able to run stock 317's?
Old Nov 16, 2008 | 07:58 PM
  #23
1FastBrick's Avatar
Custm2500's Rude Friend
Yes, when you go to a larger crank you will have to look at your piston selection and wich rod length you will need to work with the crank you want to run...
Old Nov 16, 2008 | 08:03 PM
  #24
o i thought i could run the lq9 piston just with a different set of rods, but i can run the same heads?
Old Nov 16, 2008 | 08:05 PM
  #25
1FastBrick's Avatar
Heads yes. If you change the stroke you will need to get the right rod and piston combonation. In short No you can not reuse the stock rods and pistons with a longer stroke crank.
Old Nov 18, 2008 | 07:09 AM
  #26
thanks man i appreciate it
Old Nov 18, 2008 | 02:14 PM
  #27
zx9rgreen's Avatar
lo&sloSierra
Im in Wetumpka also and building a LQ4 to replace my LS1 in my Sonoma, I have the cam in the LS1 with 918 springs and Ti retainers, hardened pushrods if you are interested. The cam specs are 228 228 571 571 112+4 .
I am building the LQ4 with PRC 2.5 heads(5.3) and a MS3 cam.
Old Nov 19, 2008 | 07:20 AM
  #28
pm sent
mikeyjm1
17
Oct 29, 2015 11:04 PM
Superman09
Sep 25, 2015 05:55 AM
MA$TER_E
Sep 9, 2015 03:14 PM
jleews6
Sep 8, 2015 10:17 AM
