6.0l build help
Old Nov 16, 2008 | 05:03 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Stick with the #317 Heads on an LQ9 Piston. 317 Heads came factory on both the LQ4 and LQ9.
The 317 Head have a 74cc Cumbustion Chamber
The 243 Head Have a 64cc Cumbustion Chamber
Aparently with 317 Heads With
LQ4 dish pistions = 9:6 compresion ratio
LQ9 flat top pistions = 10:1 compresion ratio
With a 243 Head and a LQ9 Piston I am told you will be around 11.1 compresion ratio.
Found in this thread https://www.performancetrucks.net/fo...highlight=Head
Old Nov 16, 2008 | 05:11 PM
dirt track racer 81's Avatar
I went the ls1 head route when i first put in my 6.0, once i built my 370 i had them on there for a bit then i put 243s on it and i wish i did that along time ago. ls1 head on a 6.0 is a bad idea
Old Nov 16, 2008 | 05:13 PM
1FastBrick's Avatar
By LS1 Head are you refering to the 241 Heads???
Old Nov 16, 2008 | 05:17 PM
yes the 241. i did alot of port work on them
Old Nov 16, 2008 | 05:26 PM
1FastBrick's Avatar
LOL... I remember when they were all the rage Like swaping to an LS1/LS6 Style intake on truck motors... untill people found out The hard way what a waist of time and money it was....
Now I keep seeing them pop up at local swap meets and people think there gonna get big money for them. Kinda like the early LS1 blocks That can only go like .005 over Because of core shift and liner thickness...
I was told by a certin Head porter That He would not even mess with them any more. There vertually worthless... and the real early LS1 heads like 853 and 806 are really crappy
Old Nov 16, 2008 | 07:14 PM
lo&sloSierra's Avatar
i have a set of 241's, but guess it looks like my best route is to go with a 317 head on lq9 pistons
Old Nov 16, 2008 | 07:17 PM
1FastBrick's Avatar
I am only posting what I have found using the search....
Look at this Head comparison for Stock flow rate's... It looks like they flow the same in sock form
https://www.performancetrucks.net/fo...6&postcount=17
Old Nov 16, 2008 | 07:20 PM
ok so far this is what i got , the block, lq9 pistons, stock crank (but iam really starting to think about going with a larger stroke crankshaft, any suggestions, possible links?) and i got to get some 317 heads, can i run my 4.8 intake no problem on this?
Old Nov 16, 2008 | 07:22 PM
1FastBrick's Avatar
From what I understand the truck Intakes are all the same 4.8 -6.0 difference would be EGR or no EGR and Cable driven Or Drive by wire TB from 99-05 After that I am not sure of all the options for the trucks
Old Nov 16, 2008 | 07:32 PM
ok mine should work then, thanks
