6.0L/4x4s with Pacesetters
Old Jan 31, 2007 | 03:35 PM
12secSS's Avatar
Default 6.0L/4x4s with Pacesetters
I tried searching for others who have installed Pacesetter long tubes on their 6.0L 4x4 trucks, but the search comes up with a butt load of 5.3L installs. No offense 5.3L guys. The main concern I have is that my exhaust is a "true dual" setup, routed through the passenger side though. It still has the stock manifolds with OE cats and silencers bolted up to the Gisbon exhaust. The Y-pipe Pacesetter shows is an actual Y-Pipe, two into one. That will not work with my exhaust. I am trying to figure out if the 6.0L had a different exhaust setup vs the 5.3L/4.8L ... or if mine is custom? So, what are the 6.0L 4x4 guys doing? Any 6.0L 4x4 guys have pics? I plan to install them this weekend, weather permitting.
__________________
George P. Lara: 2001 Camaro SS #0391
HPTuners for '98-'02 F-Bodies & '99-'02 Trucks
Jenibella Racing Crew Chief
1998 Camaro Z28: 9.94 @ 137, 1.45
Old Jan 31, 2007 | 09:48 PM
blown3qtr's Avatar
My 6.0 has true duals also. I was wondering the same thing about the pacesetter y-pipe.
You could always have a flange or slip joint welded on.
Old Jan 31, 2007 | 10:02 PM
Nick™'s Avatar
the Pacesetter y-pipe is only available for the single outlet. 6.0 trucks from the factory have a dual in, single out muffler. You'll have to do a custom y-pipe most likely because of the 4L80e tranny. You can PM the user: BradS he has an 01 1500HD with Pacesetters and a custom y-pipe and he should be able to post up some detailed pics of his installed.
Old Jan 31, 2007 | 10:07 PM
KevinF56's Avatar
go to a muffler shop and have them bend you up some custom pipes
Old Feb 1, 2007 | 12:56 AM
tenshikurai's Avatar
I can't vouch for the Pacesetter ones, but the OBX kit is a true dual. They both run down the passenger side, and they fit fine on my 4x4.
Old Feb 1, 2007 | 09:46 AM
12secSS's Avatar
Ah good. I was beginning to think the previous owner did a one-off job. Well looks like I will be fabircating my own Y-Pipe. I am going to try and reuse the stock piping, possibly relocated back a tad. I measured it the other night and it spec'ed out at 3". I will PM BradS and see if he can provide me with some images of his Y-Pipe. Thanks for the help guys, and I will try and take pictures of my install and after I complete it.
I wonder if I can squeeze in a quick dyno session somewhere, prior to the install?
Found BradS's post, he even included pics and video ... how nice.
https://www.performancetrucks.net/fo...ght=pacesetter
Old Feb 1, 2007 | 10:19 AM
2006 8.1's Avatar
Any of the HD model trucks should have dual cats and duals all the way to the muffler and then they exit as duals they Y to a 3.5 inch single tail pipe. Makes putting aftermarket true duals very easy. I have done it on two different 8.1s
Old Feb 1, 2007 | 02:47 PM
HvyChevyZ71's Avatar
I have a true dual set up with pacesetters, the muffler shop just custom bent the exhaust tubing and I run di/do magnaflow.
blown02408
Feb 24, 2016 04:50 AM
Cowboy Tom
11
Sep 16, 2015 09:35 AM
bisqikss
Sep 8, 2015 03:35 AM
USMCvet0311
Sep 4, 2015 09:43 PM
Layn22s
Aug 31, 2015 03:43 PM
