6.0 to replace 4.8
Old Jun 18, 2009 | 07:17 AM
  #31
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by ou812sm
so if i took the fan off of the 4.8 would it bolt up also does 6.0 use a bigger radiator
The 4.8 fan should bolt right up to the water pump pulley of the 05, every one that I've seen has had the threaded provision for it, but double check just to be sure.
Yes, the 6.0 uses a 34" radiator as opposed to your 28" radiator, I believe that all trucks that came with efans also have the 34" raditiator, so you'll need the 34" rad to make the efans fit your truck. I got my 34" rad from the radiatorbarn.com for around $265 shipped IIRC.
smokeshow
Aug 23, 2015 08:23 PM
JordanH
Aug 8, 2015 07:59 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Suburban2500
Jul 19, 2015 04:50 PM
