Fast injectors
Old Jun 9, 2009 | 10:06 AM
lownslo's Avatar
Default Fast injectors
Have any of you all ever used their injectors? The reason i ask is I am having difficulty finding a short EV6 style injector for a descent price! I had a friend hook me up with new fast injectors and here are the specs:
57#
uscar plug
Shorties
FAST™ Precision-Flow™ Fuel Injectors for GM Gen IV engines are the highest flowing injectors available and are uniquely designed for direct installation into LS2 and LS7/L76/L92- style engines. Available in two different height configurations and a wide range of flow rates, the new Precision-Flow™ Fuel Injectors are correctly sized (shorter than the common LS1/LS6 injectors) and feature the correct USCAR connector, enabling hassle-free plug-in operation. In addition, the high-impedance, high-flow FAST™ injectors meet/exceed all factory durability standards and quality tolerances.
Prior to the arrival of Precision-Flow™ Fuel Injectors for GM Gen IV engines, performance engine builders were required to retro-fit high-flow Gen III (LS1/LS6) injectors which required a wiring harness adapter to fire the injectors. Most importantly, due to the fact that LS2 and LS7 engines feature shorter fuel injectors than other LS engines, when performance injectors were required engine builders would have to modify the fuel rail placement to fit the Gen III (LS1/LS6) style injectors. The new FAST™ Precision-Flow™ Injectors for GM Gen IV engines are simple drop-in components offered in fuel rates up to 57 lb/hr* (LS2–type) & 65 lb/hr* (LS7/L76/L92-type), the highest rate currently available for GM Gen IV engines.
*fuel delivery rates are based on 58psi fuel pressure
keep in mind i will be running a 70mm turbo on 8psi with a lq4 6.0!
What are your opinions?
Old Jun 9, 2009 | 02:32 PM
lownslo's Avatar
nobody has input on these injectors?
Old Jun 18, 2009 | 11:55 AM
BlownHD's Avatar
I too am curious about these injectors, I want to do some more power adders, but I need more fuel first.
murderedSS
27
Oct 12, 2015 11:13 AM
OHsixLS3
Sep 25, 2015 11:20 AM
jroctpb
Sep 16, 2015 09:05 PM
lxcoupe
Sep 2, 2015 12:58 AM
