6.0 to replace 4.8
Old Jun 15, 2009 | 09:55 AM
  #21
ou812sm's Avatar
will a 6.0 out of a 05 escalade bolt up to my tranny if my truck came with 4.8
Old Jun 15, 2009 | 11:11 AM
  #22
budhayes3's Avatar
PT's Slowest Truck
Yes it will
Old Jun 15, 2009 | 10:21 PM
  #23
ou812sm's Avatar
does anyone knows if 05 had efans or belt driven fans
Old Jun 15, 2009 | 10:39 PM
  #24
_zebra's Avatar
makes children cry
Originally Posted by 03 BLACKOUTSSS
thats a question of your budget...not opinion. Do alot of reading. First I would say find and purchase a motor. That way you have something very specific you can ask questions about. It will be easier for you to identify the differences between what you have and what you are installing if the motor is in front of you. personally, 6.0s go for about $1k, 5.3s go for aabout $250. there are some pretty strong running 5.3s out there, plus it leaves a bit more money for mods (cam, P&P heads, etc...)
any info on where i can get a 5.3 for that price?
05 is when they switched to e-fans
Old Jun 16, 2009 | 11:48 AM
  #25
budhayes3's Avatar
PT's Slowest Truck
05 should have efans
Old Jun 16, 2009 | 02:19 PM
  #26
ou812sm's Avatar
what do i need to get to convert to efans if i have an 04 4.8 tahoe
Old Jun 16, 2009 | 09:04 PM
  #27
budhayes3's Avatar
PT's Slowest Truck
If you go with LS1 fans, you'll need the fans, a fan harness (you can make this yourself or buy one pre-made from some of our sponsors, I have the Nelson harness and it fits and works great), some home made brackets for the fans (metal strips basically), and PCM tuning to turn the fans on and off at the pre-determined temperatures. For 05 fans, you'll need all of the above, plus a 34" radiator.
Old Jun 16, 2009 | 09:29 PM
  #28
ou812sm's Avatar
how hard is it to change the 05 efan to belt driven fan
Old Jun 17, 2009 | 12:21 PM
  #29
budhayes3's Avatar
PT's Slowest Truck
I *think* that it's as easy as removing the 05 fans, getting a clutch fan and fan shroud (for a 34" radiator), and bolting them in. Might have to tweak something in the PCM since the fans will no longer be plugged in...not sure if the PCM monitors that or not.
Old Jun 17, 2009 | 08:40 PM
  #30
ou812sm's Avatar
so if i took the fan off of the 4.8 would it bolt up also does 6.0 use a bigger radiator
