6.0 Heads on a 5.3L
Old Mar 3, 2002 | 08:02 AM
Default 6.0 Heads on a 5.3L
Has anyone done 6.0 heads on a 5.3L. I was wondering what kind of mods id have to do to fit them, and run them in conjuction with my S/C. Any Ideas??????
5.3L Ford Spark(Lightning) Killer
J from Dirty New Jersey
Old Mar 6, 2002 | 02:04 PM
CHAGO's Avatar
Default Re: 6.0 Heads on a 5.3L
i heard that everything from a 6.0 will fit on the 5.3 since they are almost identical blocks.
same thing with the ls1 camaro's, most of the mods done for those will also work for the 5.3
Old Mar 6, 2002 | 07:20 PM
GREGGO's Avatar
I doubt you will see any eye-popping gain with just stock replacement heads. Now if you P/P them add some Comp springs and Valve job that would give a nice increase. Yes they will bolt right up w/o any modifications.
Old Mar 6, 2002 | 08:55 PM
really slow truck's Avatar
if you do a search this has been asked a few times before.
basically if you dont get work done to them you will actually lose power because of the larger comustion chamber. they do flow a little better, and im not sure if your looking to lower your compression to run more boost or not, but im not sure how much the larger chamber would end up lowering your compression.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
greedygenius
Sep 3, 2015 06:51 AM
JordanH
Aug 8, 2015 07:59 PM
05GMC4.8
Aug 7, 2015 09:55 PM
steves86ta
Jul 28, 2015 10:21 AM
