Do I have everything I need for my cam swap?
Old Mar 29, 2003 | 02:58 PM
Ryan23silverado's Avatar
Default Re: Do I have everything I need for my cam swap?
I would get new water pump gaskets. Others say they can be reused, but the silicon bead on mine was crushed. A harmonic balancer bolt should also be gotten since it is a torque to yield bolt. And buy some assembly/ camshaft break in lube from your local auto store. Use a ton of this when installing the cam and put a dab of it on the pushrods before you put the rocker arms back on.
Old Mar 29, 2003 | 03:54 PM
11 Second Club
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Ryan23silverado:
<strong> I would get new water pump gaskets. Others say they can be reused, but the silicon bead on mine was crushed. A harmonic balancer bolt should also be gotten since it is a torque to yield bolt. And buy some assembly/ camshaft break in lube from your local auto store. Use a ton of this when installing the cam and put a dab of it on the pushrods before you put the rocker arms back on. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">u dint need assembly lube just oil., coat the cam with oil an u will be fine.
Old Mar 29, 2003 | 06:33 PM
The lube puts a good barrier between the cam lobes and the cam bearings when putting in the new camshaft. (at the risk of later jokes in this post) The lube makes it slide in easier than just the oli. It cost like $2 also. Yes, you could just use oil, but the main thing is to make sure the camshaft goes in straight and does not knick any cam bearings. The assembly lube coats any cam bearing shavings that may come off.
Some more advice: make sure the inside of your camshaft is cleaned out. When I got mine from Crane there were a buch of metal shavings still sitting inside of the drilled center of the cam.
Old Mar 30, 2003 | 12:48 AM
14 Second Truck Club
Default Do I have everything I need for my cam swap?
I ordered 2002 ZO6 springs & Thunder Racing Pushrods for my Crane Cam -
208/216 - .530/.530" lift - 113LSA
Thats all I need right?
Old Mar 31, 2003 | 07:11 AM
jlwz71's Avatar
Beer <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" />
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
Aboss
Jul 9, 2015 10:28 AM
GreyChevy
Jul 7, 2015 08:57 PM
