6.0 build for blower
Old Jan 21, 2020 | 08:35 AM
  #101
dantheman1540's Avatar
The Kellys look to have great reviews but the Q speed rating is a little low and they are actually a couple bucks more per tire than the KO2s which is surprising. I hate being stuck on a tire type I was really ready to try the new Falken AT3W but they are $100 more per set than the KO2s and only come in load E like every other option I see.
I don't mind the Load E but Id like to see how a softer sidewall would effect ride quality and 10-12lbs per tire is a big difference in weight. Especially when I have to tote them around and take them on and off to do maintenance. Plus I don't rock crawl or tow very often or much.
Old Jan 21, 2020 | 08:46 AM
  #102
arthursc2's Avatar
Should still experiment with air pressures in the sand when you do play just be gentle on the drifts as you get down under ~20psi lol
Old Jan 21, 2020 | 08:58 AM
  #103
To be honest I usually run about 30-35psi everywhere and I've never been stuck but when towing my 18foot trailer with mud toys through sugar sand I've come dang close and then I bought a portable air compressor so if I do need to air down I can air back up. Most of the time its just playful sand blasting.
Old Jan 21, 2020 | 09:28 AM
  #104
Well for some reason I expected the load C tires to weight less but it appears the Load E tires weigh 62.4lbs each and the load c are 63lbs each strange.
Old Jan 21, 2020 | 09:41 AM
  #105
arthursc2's Avatar
Where did you see the weight listed?
Old Jan 21, 2020 | 09:42 AM
  #106
On Discount tires web sight and I double checked it here https://tiresize.com/tires/BFGoodric...-315-70R17.htm
Old Jan 21, 2020 | 09:49 AM
  #107
arthursc2's Avatar
Interesting indeed. Guess get the E's
Old Jan 21, 2020 | 10:00 AM
  #108
Yeah comparing nearly every brand tire in that size the lightest is the KO2 in load E at 62.4lbs. I'm kinda shocked.
Old Jan 21, 2020 | 01:36 PM
  #109
GREENSIERRA's Avatar
I am surprised the bfg are cheaper. Where I am from kelly are around $500 cheaper a set.
Old Jan 21, 2020 | 01:45 PM
  #110
Jeez $500 cheaper and they would probably already be mounted. I've found the load C KO2s for $247 a tire that's mounted and balanced. The Kellys are $274 each. I'm thinking my local Discount tire must get a great deal on BFGs because they are about the cheapest option in the size period which I find strange.
