Which 6.0 Block?
Old Nov 13, 2004 | 11:16 PM
ChevyTrukRacer99's Avatar
Default Which 6.0 Block?
I am starting to keep my eye out for a 6.0 block to build on... are there different ones, if so which one is better? Advantages to different blocks etc... Thanks in advance guys.
D
Old Nov 13, 2004 | 11:22 PM
parish8's Avatar
single digit dreamer
i am prety sure they are all the same. just an iron 6.0 block.
brand new they are prety cheep, something like $500(not real sure). some people like them used(seasoned) too.
Old Nov 13, 2004 | 11:38 PM
PappyDan's Avatar
Tribe Shaman
about a year ago i priced onr brand new with heads was just a little over $3000.00 for a 6.0
Old Nov 13, 2004 | 11:51 PM
GREGGO's Avatar
The blocks are the same. The cranks and heads are whats different. Just get an 01 or newer if your planning on using the stock crank. Heads were Iron and cranks were longer on the 99's and some 2000's.
Old Nov 14, 2004 | 12:16 AM
buymeavette's Avatar
LQ4 has Iron Heads from years 1999-2000,LQ4 has Aluminum Heads from years 2001+, and the LQ9 has Aluminum Heads from 2002+ and has flow characteristics of a LS6. (Chevy LS1/LS6 Performance Page 64-65)
Old Nov 14, 2004 | 12:20 AM
parish8's Avatar
are we talking an entire motor or the block? thought he was just asking about the block.
Old Nov 14, 2004 | 01:15 AM
I was pretty much just talkin about a block, cause when i do a swap, i want to do it once...and do it right, so i will be buiding a motor pretty much from the block up.
Old Nov 14, 2004 | 02:14 AM
Z1500's Avatar
When you buy a new block from GM does it come with mains and main bolts all line honed? Are the cyl walls honed and ready to go at 4.000"? **** for $500 that's worth buying a new one rather buying used and getting machined.
legerwn
56
Nov 15, 2015 10:21 PM
kalikid06
20
Oct 13, 2015 07:37 AM
mitchellmade
Sep 27, 2015 08:27 PM
chvy=power
Sep 8, 2015 11:06 AM
