5.7 wont run
Old Aug 28, 2008 | 09:35 PM
viciousknid's Avatar
Where's the Beef?
Default 5.7 wont run
Friends got a 5.7 that will fire and die when you crank it. If you dump fuel in the TB it will stay running.
I don't know for sure yet if i can scan it. but some of you might know whats wrong.
Injectors maybe?
Old Aug 28, 2008 | 09:40 PM
Where's the Beef?
Sorry. Undid the fuel line up top and its getting fuel.
Old Aug 28, 2008 | 10:19 PM
hog's Avatar
hog
What year truck? Whats teh fuel pressure? geting fuel doesnt necessary mean you have enough PRESSURE. The 96-98 350's need 55-66 psi to run.
peace
Hog
Old Aug 28, 2008 | 10:23 PM
Where's the Beef?
its a 98. I should be able to scan it tomorrow with EFI Live.
I'm kinda the 3rd party guy so far. My dad and the owner are working on it and calling me for suggestions.
I'ma run out to it tomorrow and have them change the fuel filter. Apparently it had bad gas in it for a while and the filter hasn't been changed. I don't have anything to check the pressure tho.
appreciate the suggestions. anything else i should look for if that checks out?
Old Aug 28, 2008 | 10:28 PM
dirt track racer 81's Avatar
like hog said just cause fuel is coming out doesnt mean its at enough pressure to run..it should spray out a good 3-5 feet..get some good gas in it..is it settin any codes? tell your dad not to touch the distributor or try to take it out..you dont use a timing light to set that
Old Aug 28, 2008 | 10:41 PM
Where's the Beef?
lol no worries there.
I'm going to check for codes tomorrow and see the fuel myself. My dad said its coming out really strong. My guess is the gas. I asked how much bad gas was in it before they put more in but he didn't know. so i'll have to look at that as well.
They had injectors on the 5.7 didn't they? If so i'm gonna have them undo one and see if fuel is getting that far.
Old Aug 28, 2008 | 11:04 PM
they just have 1 injector
Old Aug 31, 2008 | 02:31 PM
hog's Avatar
hog
They actually have 8 individual injectors.
Some pics in this thread. Go to post#9
https://www.performancetrucks.net/fo...d.php?t=356743
The injector/poppets are inside the intake and cant EASILY be shut off individually.
Spend $30 and get a fuel pressure gauge. The Vortecs wont start under 50 psi as there isnt enough fuel pressure to unseat the poppet valves.
The key indicator here is that the truck starts WHEN FUEL IS POURED INTO THE T_BODY. That emans it has spark and air, it just needs some more fuel.
Fuel pump IMO.
get the fuel gauge, theres a test port on teh fuel rail in the drivers side of the intake.
peace
Hog
Zizzle
Oct 19, 2017 08:44 PM
stealthperf
34
Feb 14, 2016 11:35 AM
Go5.3tt06
Sep 12, 2015 09:29 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
grantpo
Jul 15, 2015 12:21 PM
