5.3 tb work on a ls6 intake?
Old Jan 31, 2009 | 09:59 PM
Taubr Unit's Avatar
Default 5.3 tb work on a ls6 intake?
searched and found nothing. Will a TB off a '01 5.3 work on a ls6 intake? I heard that the vaccum tube gets in the way of the throttle bracket. Tru? Or should i get a ls1/6 TB?
Old Feb 1, 2009 | 12:46 AM
454navyss's Avatar
i dont know for sure but why cant you re-route the vacuum tube so it doesnt get in the way?
Old Feb 1, 2009 | 01:04 AM
viciousknid's Avatar
Where's the Beef?
In the ls6 intake swap write up I didn't see any mention of having problems using a Truck TB
https://www.performancetrucks.net/fo...&highlight=ls6
Old Feb 1, 2009 | 01:36 AM
yes. But I believe it will have a smaller inner diameter of the LS6 intake.
LS6/1 intakes have ~78mm intake opening. I think the trucks were a bit smaller. Might as well go to a up pull-it and get one from a camaro or something. Do you need drive by wire? If so I believe the LQ4 or LQ9 trucks had the same inner diameter of the LS6. Don't quote me though. It was either the same as the LS6 or LS2 (90mm).
Old Feb 1, 2009 | 02:02 AM
budhayes3's Avatar
PT's Slowest Truck
All of the truck throttle bodies (4.8 through 6.0) were the same size (78mm), prior to the switch to the LS2 style intake. Not sure if they'll bolt directly up to the LS6 intake though, but I believe that they will.
Old Feb 1, 2009 | 02:05 AM
Ok they are the same. I don't see why it wouldn't just 3 or 4 10mm bolts.
Old Feb 1, 2009 | 09:07 AM
closet red neck's Avatar
Yes, they it will fit. I replaced my stock tb with the bbk tb way back in the day when the truck intake was still on the engine. During the swap, I reinstallled the bbk onto the LS6 intake with no issues.
James
5.3Okasai
Mar 9, 2022 01:07 PM
ARC
57
Feb 21, 2022 10:54 AM
byrne_06
Apr 29, 2017 02:19 PM
The_W
Oct 28, 2015 09:00 PM
07NBSChevy
20
Jul 8, 2015 07:27 PM
