5.3 swap to 6.0 ect
Old Apr 19, 2007 | 10:26 PM
gmc 5.3's Avatar
Registered User
Question 5.3 swap to 6.0 ect
Was this a swap that you would do again?
Did it all go throught nice and easy bolt up right ?
Are the wire harness's all the same?
I have a 04 gmc sierra 4x4 and i was thinking about a 6.0 ss motor.
Is it trou that the ss motor's are 6.0 350hp?
Thanks
Old Apr 20, 2007 | 12:52 AM
ridnlow's Avatar
I wish I would have done it 3 years ago and would do it again in a heartbeat..
it was very simple..
used my 5.3 wiring harness.. no problems..
SS 6.0 which is the lq9 makes 345HP...
Old Apr 20, 2007 | 02:32 AM
RoosterMcCandles's Avatar
Search is God...
Old Apr 20, 2007 | 09:18 AM
Tootall's Avatar
search it up, just type in "6.0 swap" There's all kinds of write ups
Old Apr 20, 2007 | 02:10 PM
gmc 5.3's Avatar
Registered User
i was searching 5.3 swap 6.0 and it wouldnt work
Old Apr 20, 2007 | 02:33 PM
xlcooplx's Avatar
helped my buddy do his. the only problem we had is the fuel lines on his 00 intake were different than the fuel lines on the 04 intake. also, there was a black plastic sensor on the top of the rear of the block that had to be changed. other than that, it was a direct swap.
Old Apr 20, 2007 | 02:46 PM
Tootall's Avatar
Don't worry about swapping out the ENTIRE motor. You're only swapping out the heads/block and that's it.
Search a little more, LOTS of the componets are the same. Same part No. same specs. same size, same bolt pattern.
Bumpers
Aug 4, 2024 09:44 PM
greedygenius
Sep 3, 2015 06:51 AM
OLD BULL
Aug 1, 2015 05:00 PM
steves86ta
Jul 28, 2015 10:21 AM
ls2 dude
Jul 25, 2015 11:08 PM
