5.3 Questions
Old Dec 24, 2010 | 08:59 PM
Whitelightin2005's Avatar
Default 5.3 Questions
How do i know what parts such as cams,lifters and such will work in/on my 05 5.3? and also where can i find a set of SS gauges for my cluster?
Old Dec 24, 2010 | 11:59 PM
badz24s's Avatar
formerly b4vwannabe (2/4/2012)
I believe any cam & lifters will work as long as they are for an LS motor. Basically what I did to kinda school myself on the subject is to read thru every thread that's in the ballpark.
As far as SS guages, ebay will be your best bet.
Old Dec 25, 2010 | 09:00 AM
.James.'s Avatar
^^ what he said. lots of options and opinions on cams, and lifters, depends what you are trying to achieve, and what you want to spend
Old Dec 25, 2010 | 07:25 PM
I just wanna get my truck pretty quick....i dont wanna have it running 10's in the 1/4 but a pretty good stop light to stop light truck if you know what i mean!!!! ive talked to a few folks up here and they talked in language that i didnt understand. This new motor **** is new to me with the "LS" LSX and all that...im use to the old still big and small block motors...Just trying to achive a pretty quick truck and still be my daily driver..thanks
Old Dec 25, 2010 | 07:58 PM
1slowz71's Avatar
well it all perty easy all ls base motor the parts are inter changeable ,4.8L, 5.3L , 6.0L ,LS1 ,LS2, so when you look for parts you can look for them by ls1 parts , but if you want to be a little faster, cam it and tune it i always say its a little more over stock but enough to smoke the sh*t out of a lot of trucks and sport cars! as far as what cam stick around , if your a 5.3 with no stall i would recommend the tsp220 or voodoo 212/218, and if your going to run a stall i would say the tsp 224, IMO!
Old Dec 25, 2010 | 08:40 PM
Ive been hearing alot about the stalls and everything. whats the advantage to running a stall vs. not running one? with it being my daily driver.
Old Dec 25, 2010 | 08:56 PM
badz24s's Avatar
I am by no means an expert on it, but basically, it just puts you in your power range sooner. I haven't installed mine yet(circle d 3200) but say when you take off from a start, you'll be more in your power range when you start moving. Instead of it starting to move at 1500RPM, you'll be closer to 2500RPM when you start moving. That's the way I understand it. It also keeps your RPMs from dropping a lot between shifts.
a torque converter with a higher stall = higher trans temps. If you do get a higher stall converter, you need to also buy a larger trans cooler, specifically a TruCool 40K cooler.
Main thing to do is just pay attention to the threads, read as many as you can and you'll learn a lot. Don't be afraid to ask questions. There will be some that will immediately fire back with a reply that says to search. A lot of the guys here that really know their stuff are very helpful.
Old Dec 26, 2010 | 06:01 PM
I was talking to my dad about all this this morning and talking about the stall. And he informed me that since i do hunt with my truck and goes in mud some that i didnt need a stall and a good cam which pulls strongest from low thru midrange
Old Dec 26, 2010 | 06:30 PM
5.3 GMC's Avatar
Depending on what stall you get depends on stall speed. Some are set up loose and some are tight. I have a Yank SST 3200 and mine gets moving about 1500 rpm. A circle d 3200 may not get moving till over 2k or closer to 3. Depends on the brand. Best thing to do is ask around IMO.
ferrellrooster
Mar 6, 2025 03:22 PM
USMCvet0311
Aug 1, 2015 07:45 AM
vmaxpro
Jul 27, 2015 10:45 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
grantpo
Jul 15, 2015 12:21 PM
