5.3 to LQ4 swap
Old Jun 16, 2010 | 03:15 PM
easyrider ls6's Avatar
Talking 5.3 to LQ4 swap
Hey guys! got a 02 Sierra that is going to get a new motor. Been pondering the thought of doing the 6.0 swap. Just what all does this involve. Been told the harness will not work. Also been told the 4L60 will not work. What gives? Found a LQ4 with 50K on it for $1500 complete with acc. Really would like to have a motor with alot of attitude. The more I read on here the dumber I get-Brainstrain!
Old Jun 16, 2010 | 03:36 PM
sureshot's Avatar
Your harness and 4L60e will work. All of your accessories will work as well.
Old Jun 16, 2010 | 03:38 PM
sharpshooter's Avatar
what year LQ4?
Old Jun 16, 2010 | 03:42 PM
The LQ4 is a 04 . It is all stock but would like to build it before install.
Old Jun 16, 2010 | 03:45 PM
what is in your sierra now?
Old Jun 16, 2010 | 03:47 PM
sureshot's Avatar
it's a 5.3
Old Jun 16, 2010 | 03:55 PM
StrokerAce03's Avatar
Swap the flexplate from the 5.3 to the LQ4 and everything else is plug and play. You could even run it on the stock tune but definitely get it retuned.
Old Jun 16, 2010 | 04:04 PM
LS1FREEK's Avatar
13 Second Truck Club
It's a direct swap (besides the flexplate). Pull your 5.3 and set it next to the 6.0 and you'll see that they're identical, on the outside anyway lol.
Old Jun 16, 2010 | 04:08 PM
LS1FREEK's Avatar
O and you'll also need to take the intake manifold and throttle body off of the 5.3 and reuse it as well. Don't worry, both manifolds and throttle bodies are the same size and flow the same amount of air.
Old Jun 16, 2010 | 04:12 PM
sureshot's Avatar
Yup, other than the intake, throttle body, and flexplate, it's a direct swap. As stated, the blocks are identical on the outside. I reused all of my accessories as well. Also, if you don't have longtubes and want to do them, now is a perfect time. When you get the old motor out, lay the longtubes in, drop the new motor in, and bolt them up!
