5.3 Injectors?
Old Mar 2, 2008 | 08:17 PM
da_vato's Avatar
Default 5.3 Injectors?
Does anyone know of the cheapest place to get 40-44lb injectors? I find them from about $325 - $425. And what other brands will fit, or is Delphi the only brand I can use? Ive heard you can use corvette injectors too, is this true?
Old Mar 2, 2008 | 10:01 PM
Mangled03gmc's Avatar
Baltimore Whore
The delphi shorties, are a direct fit. Look in the classy now, there are a few there that are going for 2xx.. Or look on ls1tech..
John
Old Mar 2, 2008 | 10:25 PM
LowBlack99's Avatar
The vette injectors have different harness plugs and aren't much higher flow than stock truck injectors with the exception of the 8.1 injector.
Old Mar 11, 2008 | 12:27 PM
06 TRed GTO's Avatar
Will a set of 42lbs ford green tops bolt rite up or will they need some mods also?
Old Mar 11, 2008 | 01:05 PM
kbracing96's Avatar
No, they're not plug and play. They have different connector plugs on them and you have to space the fuel rail up 5/8 of an inch cuz there taller.
Old Mar 11, 2008 | 03:34 PM
So is this what I need for plug and play
42# DELPHI - Marine 8.1L
Old Mar 11, 2008 | 04:11 PM
silver-mod-o's Avatar
Hunt&Fisherator
that should do it
Old Mar 11, 2008 | 04:39 PM
silveradokidd_4518's Avatar
just bought mine off a member here the other day
Choda
Jan 22, 2026 02:03 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Sexyrado327
Aug 2, 2015 04:08 PM
MS3Z
Jul 30, 2015 06:17 PM
vmaxpro
Jul 27, 2015 10:45 PM
