5.3 to 6.0 swap
Old Jan 27, 2005 | 06:08 PM
  #61
MrXerox's Avatar
Originally Posted by Randy Grabert
WILL LET SEE MY FRIEND BOUGHT A 6.0 GOT VALVE JOB SHAVED HEADS CAM AND SPRINGS FOR ABOUT 1500.00.( NOT A NEW MOTOR) I CAN GET 6.0 BETWEEN 600 AND 1500 IT ALL DEPENS ON THE MILEAGE YOU ARE LOOKING FOR THE MOTOR TO HAVE MY FRIEND HAS ONE CAME OUT OF 03 HD WITH 3K ON IT HE WANTED 1500.00 FOR THAT ONE ALL THE REST ARE 1000.00 AND LESS.WE PULL CAB OFF OF FRAME MAKES VERY EASY EVERYTHING IS THERE AT WAIST HIGH DON'T HAVE TO WORRY ABOUT THE PAINT JUST UNHOOK THE FUSE BLOCK UNDER THE HOOD AND THE BODY BOLTS AND THE STEERING SHIFT AND TRAN CABLE AND GO TO TOWN
If you are getting motors for that cheap, you are buying them from a chop shop! Besides, the motors I am speaking of are direct take outs with less than 10 miles on them and come complete with all accessories (alt, a/c, p/s, etc...) full wiring harness and PCM. They are available without all that as well for a little cheaper but the LQ9s are sold fully dressed only...
Old Jan 27, 2005 | 06:58 PM
  #62
retsell's Avatar
Originally Posted by gonzo 6.0
I believe the only right way is to pull the intake off,i then used the rear bracket with a chain hook and I drilled a hole in the bracket to run a safety bolt thru the chain.On the front i built a bracket that attached to two of the acc.head bolt holes
Why is the hood still on this truck!?? Makes more work for yourself...
Old Jan 27, 2005 | 06:59 PM
  #63
sebcat's Avatar
Originally Posted by nitrorbc
Hey would you mind sending me a pm with a link as well?
mee too!
Old Jan 27, 2005 | 10:03 PM
  #64
rosscob's Avatar
I WOULD LOVE TO GET ONE OF THOSE PM'S!!! The best deal I have found is on an lq4 from Highway Auto in Brownwood TX. '03 with 25k for $1300 complete.
Old Jan 27, 2005 | 10:07 PM
  #65
Mr. Sandog's Avatar
Guys, don't waste your time, this is no deal, what gets forwarded to you is a link to the same National database that http://car-part.com uses.
Old Jan 27, 2005 | 10:39 PM
  #66
TXsilverado's Avatar
whats the reason behind them being taken out after 10 miles???
Old Jan 28, 2005 | 07:51 AM
  #67
MrXerox's Avatar
Fyi, He just happens to be a member of car-part.com like ever other part yard out there and links to that search engine on his web page... The way I understand it is they receive a portion of all vehicles that are damaged in any way in transit to the dealership (train derailments to transport accidents, etc...). I have seen a row of vettes over there with not much more than dings on the hood. However, if that vehicle were to be purchased after being repaired GM would be setting themselves up for a huge lawsuit therefore they ship the entire vehicle to him and he dismantles it and parts the good stuff out... Dont get me wrong, he is not GIVING these things away, but you will be hard pressed to find a brand new motor like this with full warranty for the money. If a simple phone call is a "waste of time" then you are way to busy to be on this message forum.
Old Jan 28, 2005 | 03:32 PM
  #68
gonzo 6.2's Avatar
Not having to remove the hood made less work.Everyone will have a differnt way of doing things.Worked for me and worked on my buddys Denali.May not work for you.
Old Jan 28, 2005 | 06:32 PM
  #69
retsell's Avatar
I was just giving you a hard time.
Bumpers
Aug 4, 2024 09:44 PM
OLD BULL
Aug 1, 2015 05:00 PM
steves86ta
Jul 28, 2015 10:21 AM
Jake75
Jul 22, 2015 09:20 PM
Cowboy17
Jul 9, 2015 06:18 PM
