4l80e/6.0 runs great!!
Old Nov 22, 2003 | 03:54 PM
  #21
XLR8NSS's Avatar
Adkoonerstrator
SWEEEEET!![/Dodge_Hemi_BurnoutDude]
EFILive is leap years ahead of ATAP for logging speed. If your used to ATAP you will be overwhelmed by the amount of data you get in a EFILive log.
Jim - I'll be sending a PM your way after a little while. Got some errands to run real quick.
Old Nov 22, 2003 | 04:28 PM
  #22
Flyer's Avatar
That's a good way of putting it. I remember seeing my first EFILive log and thinking OMG .. how the hell am I gonna sort all these lines out.
Old Nov 22, 2003 | 06:14 PM
  #23
Flyer's Avatar
Was on eBay and found this ...
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2444134663
Old Nov 22, 2003 | 11:23 PM
  #24
MGMC's Avatar
12 Second Club
Good job parish, I cant wait to see some numbers!
Old Nov 23, 2003 | 11:03 PM
  #25
parish8's Avatar
single digit dreamer
tuning has begun but what a pain, i really liked my new lap top till i started all of this. i had to borrow an old lap top from somone so i could log with atap, the new one will do edit but not very well, it usualy takes me about 10 conect attempt to get it to work and i still havn't figured out the routeen. usb-serial sucks!!
anyways, ltrims were way high so i adjusted the ifr, that made a huge diference and it definately pulls harder now. anything under 20mph and i have to get out of the throttle or it is bouncing off the limiter. most of the time at 30mph it rips a nice long fishtail but not so much i have to let off. bumped the shift point up to 5600, raised the rev limiter, got rid of PE delay.
i tried to figure out how to hook up a switch to the front differential but it was trickier than it seems it should be so tomorrow i have to get some wireing diagrams. once i have 4wd i will be geting some new gtech times, i haven't even got to launch it yet. 1st gear is done about 50mph and 2nd goes to over 90mph. my maf numbers are maxing out about 31lb/m.
best of all it runs great, smooth and quiet.
Old Nov 23, 2003 | 11:08 PM
  #26
Black Blown 02's Avatar
What did the maf max at with the 4.8?
Old Nov 23, 2003 | 11:15 PM
  #27
parish8's Avatar
that info is on the laptop that i ruined so i can't tell you for sure but it seems like it was 24 or 25, that is a good question though, i might try and recover those logs.
Old Nov 23, 2003 | 11:23 PM
  #28
sleepersilverado's Avatar
Efi live is sweet and yess there is a lot of damn info on there. Flyer i have thought about a th350 and it is an easy swap and a cheep one. you can get a built th350 and verter fot like 1300$ but the reason i dont want to do that is no lock up=horrible gas mielage
Old Nov 23, 2003 | 11:48 PM
  #29
Flyer's Avatar
What about the th400 .. does it lockup ?
Old Nov 24, 2003 | 12:17 AM
  #30
There are lock-up versions of the TH400 out there, im not sure about the 350 but im sure they did.
They came out some time in the 80s
